Results 1 to 7 of 7
    Jun 2010
    Springfield, Ma.
    3,359
    HPI esc tray for Q-base (MMP)
    I grabbed a tray from tower that a member in the P2de forum used. Its model #103676
    it fits, no real room around it but it picks it up out of the chassis for fresh air. I mounted it to the plate I had made for the original install but tape came loose a few times in fast rolls and dead stops. I like that it has a bracket for the on/off switch and the battery lead hold down. It site very secure after adding a thin 1/8 layer of trx gray packing foam.
    I can see this working better if I pull out the dremul and modify the size of this unit. I like the switch mount and that its held secure and out of the chassis tub. Guess i'll carve it down to a better size and fit then update this thread.
    Dec 2006
    4,382
    Very nice, I like it!
    Jun 2010
    Springfield, Ma.
    3,359
    I should have updated this thread. It works but you will have to pad the bottom of the tray a bit thick to "pinch" the esc in place or it moves a bit on hard bashing. It can't come out, but it does slide around in there if its got the chance.
    Jun 2010
    Miami, Fl
    6,731
    looks good, I was thinking of getting this http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
    May 2009
    Oregon/Sandbox
    654
    What motor are you running the 2400?
    Wouldn't you like to know...
    1,823
    Try this stuff holds tight and can be removed cleanly later.
    Cads, Insane RC, PWC,and BOAT CORNUCOPIA
    Jun 2010
    Springfield, Ma.
    3,359
    Chopper, 2400 event into a new sl4sh
    Insanity, I have a roll, thanks for the link. I am just checking out some alternatives.
