+ Reply to Thread
    IL
    322
    Charging lipos in parallel???
    Can i charge two idenical batterys with my thander ac6 in parallel if so if my batteys are 2000 mah each can i charge them at 4 amps now???
    Here we go again.........
    Lilydale, Victoria, Australia
    2,845
    As long as you follow a few simple precautions
    You need a main lead parallel cable and a balance lead parallel cable (or paraboard)
    Packs should be at the same state of discharge (voltage) when you connect them
    Packs should have the same cell count (size, brand, etc can be different)
    Simply add the pack capacities to come up with a charge rate
    In your case a 1c charge rate would be 4 amps
    Cheers
    Slash Platinum
    May 2009
    Southeast PA
    1,931
    I would add ... Always connect the main power leads in parallel first before connecting the balance taps in parallel.
    http://www.tjinguytech.com/charging-how-tos < Good information!!
    My rig for parallel 2S 5000 mAh packs:
    Rig for two 2S in parallel on Accucel-8:
    Shorty Rig for two 3S in parallel:
    If your wanting to do more than two packs in parallel > http://epbuddy.com/index.php?main_pa...q4esiungjhrqh3 You will need Deans to Traxxas adapters as they do not make a board with Traxxas connectors.
    I make tap adapters and power harnesses.
    IL
    322
    Thank you both the forum has been a great help ever since i got my revo and really enjoy the help and helping others
