    8
    Alligator Clip on Battery pack
    just got a super brain 992 charger (only one in stock at my local hobby shop)... but forgot to pickup the adapter for the traxxas battery... is it okay to use the alligator clip to charge the battery... i'm new to all that electric stuff and i don't want anything to blow up or catch fire
    thank you
    the bottom part clip fit inside the connector and to top part of the clip would be resting on the plastic part of the connector
    I'm sorry if that's a really dumb question
    Jun 2010
    Miami, Fl
    6,731
    it is not wyse to use the alligator clip to charge the batt, the white connector with colored wires is the balance connector.
    Ontario, Canada
    1,192
    Nope not cool.
    Feb 2009
    Medway MA
    2,104
    Its ok in a pinch, just make sure you're not charging on a metal conductive surface and dont bump the clips so they might touch together
    Nothin' like a 4 on the floor and a V8
    San Diego
    60
    see if you can tape the clips on before charging, I would do that incase the slip they can short out. But best thing would be to use the correct plug to charge
    also watch it while it charges incase something goes wrong, I always charge in a lipo bag but with your setup you cant and need to watch it
    I will most likely do that for my first charge so incase I need to return the truck the wall charger is untouched. Once im satisfied after a few runs I will either cut there plug to use on my charger to change all to deans.
    161
    I was in the same boat when I first got my charger and battery. It will be fine temporarily, but make sure that the two croc' clips don't short. Also ensure that you don't cross polarise.
    8
    ok so, make sure red goes to red black goes to black... and clip don't touch each other. I'm thinking about returning the superbrain 992 and get a onyx 235 to be able to change connector easy.
    San Diego
    60
    This is what I have only used, does all sorts of batteries. I use the alligator clips for my old dewalt battery to charge it, some old electric hedge clipper since I lost the chargers somehow. Comes in real handy. LHS sells for about $75 but alot cheaper online can do up to a 6s 5000mah http://www.hobbypartz.com/skychb6chdup.html
    I use this with it to parallel charge a bunch of batteries at the same time
