Steering issue help NON SERVO RELATED
I'm not having binding but I can't quite figure it out. I know something is off with my steering setup. I don't remember what I did in the past to the steering as it's held up quite well. I have to modify my front skid plates to fit the steering post because it sits to high. I've tried taking out the washers but the linkage looks like it will hit the drive shaft. Please take a look at my pictures at this link (because I can't seem to post pictures here) Thank you for your help. This is an annoying problem
http://www.rcuniverse.com/forum/m_10...m.htm#10479617
I can think of two possibilities: The screw that holds the post to the chassis isn’t tightened down or there’s something preventing the post from seating all the way. BTW, why did you use a washer in the first place?
I'll open up the box to check. The post itself is tight though so I don't know about that one.
I don't remember what I did to the steering in the past but if I didn't have the washer in there the whole assembly would hit the drive shaft.
- You may not post replies
- You may not edit your posts
Forum Rules
