Page 2 of 5 FirstFirst 1234 ... LastLast
Results 41 to 80 of 171
Thread: T-maxx build
  1. #41
    castalia ohio
    5,229
    haha gooder............
    Drag It!
  2. #42
    Aug 2010
    157
    next is the steering assembly. this steering is from 3.3 i heard its response is very good. and i have a 236oz servo
    [IMG][/IMG]
  3. #43
    castalia ohio
    5,229
    all i can say is my steering is good on my 3.3 compared to my 2.5. both have stock servos and linkage. i think you will like it though
    Drag It!
  4. #44
    Aug 2010
    157
    Updates
    Fixed the wing mount without any trouble.fixed the wing.....it looks awesome
    fixed the Resonator and the RC raven springs, lot of stiffness in the springs compared to the stock ones.
    i have a small question, how to raise the wing hight as it is in the same line of my engine head. will small spacers do the job.
    do i need a washer on top of the wing where the two screws fit to the mount.
    tried to fit the front brake set up, but hit a snag. the disk is little bigger than the stock one and it is blocking the bolts.
    and the pin for the cup is too small i don't know how it happened but the stock setup was working fine. there is a gap between the brake holder and the cup how fill it?
  5. #45
    Aug 2010
    157
    sorry to post again...but it really looks cool
  6. #46
    castalia ohio
    5,229
    it should stick up slightly above the head. plus the body sticks up higher than the head when mounted. so when you have both it protects the engine plenty good. even on my 3.3 wich is longer so you shouldnt have any problems especially on the short chassis.
    Drag It!
  7. #47
    castalia ohio
    5,229
    see, plenty of protection
    Drag It!
  8. #48
    Aug 2010
    157
    i was worried coz most of the time i would run without the body, the temperatures here are very high and its summer now.
  9. #49
    castalia ohio
    5,229
    i would still run a body, theres alot of parts that can get hurt super easy without one plus the filter will get dirty faster. all you need to do to keep it cool is cut a hole in the windshield and one in the back to. just like this.
    never had a problem with mine as you get alot of air flow this way and its a strait shot to the head. ive ran mine on 95+ days with no issues.
    Drag It!
  10. #50
    castalia ohio
    5,229
    i also opened it up slightly around the head itself
    Drag It!
  11. #51
    Aug 2010
    157
    hmmm 95+......how bout 110 to 122 in the peak summer.
    i dont go out till its 100 for running my truck
  12. #52
    castalia ohio
    5,229
    you will more than likely still be fine. get a temp gun and just make sure you dont overheat the plug. as long as you have a good tune you shouldnt. the key is to have a good tune though. without a body if you flip over and hit little branches and stuff it can bend your linkage, catch it and damage who knows what else. where a body with the hole through it like mine will still protect almost everything and be much safer.
    dont go over 270 degrees
    Drag It!
  13. #53
    Jun 2009
    Cocoa Florida
    3,808
    Is that a drive cup or a plastic yoke end?
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
  14. #54
    RC Turnbuckle Jr. tphill's Avatar
    Jan 2009
    Where I lay my head is home.
    3,276
    Quote Originally Posted by maximus9 View Post
    Updates
    There is a small round plastic spacer that goes in that space. I think it comes with the hex. Your lhs should have it. You may also need a longer grub screw.
    Either you are the Predator or you are the prey
  15. #55
    Jan 2008
    Sugar Hill Ga.
    8,340
    Looks like a drive cup, a stock yoke would not have the through hole.
    If youíre using a cup, the diameter of drive cups where the hex fits will vary from manufacturers, you may be able to use the trx spacer like TP said or you may need to make one to fit. I use a piece of copper tubing cut to length and drilled for the grub screws to take up the slack on some cups.
    If youíre using a cup which one are you using? And is it tapped on both sides for set screws or just one?
    You can see the spacer clearly in this pic
    I think the spacer came stock on the 2.5R model but Iím not sure since itís been a while. There are 2 different size brake hexes also.
    Looks like you have the one with the larger ID
    Here is the smaller ID hex.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXSP69&P=7
  16. #56
    castalia ohio
    5,229
    just seen it the pics of how that onboard temp thing is mounted. jw if there was a reason you did that instead of just getting a little temp gun? it would save a little weight then to.
    Drag It!
  17. #57
    Aug 2010
    157
    Thanks everybody for your help. the hex inner dia was large i found another small one and it fits perfectly fine now.i have to grind the steel disk coz its radius is little bigger then the stock one, once its done i will update you guys.
    any suggestions on the paint schemes for my warthog body...i cant wait to have it,by tmrw it should be here
  18. #58
    RC Turnbuckle Jr. morganko's Avatar
    Southeastern Wisconsin
    3,494
    your rig is looking awesome man!!
    "fat drunk and stupid is no way to go thru life"
  19. #59
    castalia ohio
    5,229
    its a warthog.......... i say paint it up halo style
    Drag It!
  20. #60
    3,494
    +1 on the Halo Warthog! That would look awesome!!
    Quote Originally Posted by 08kgraves View Post
  21. #61
    3,494
    As for raising the wing up, you could probably add something under the wing but you will probably get some flex there and it may break off then. If you look how it sits flat, I think that is why, so it has more surface area to keep it from breaking off. I think you will be ok with your current height.
    I did an brake endo with the body off the other day and it skidded across the pavement on the wing and front body posts. Never touch the cooling head but it did grind the head of the wing screw pretty good.
  22. #62
    Apr 2003
    Calgary, Alberta
    468
    Whats the zip ties on the heatsinks for?
  23. #63
    Aug 2010
    157
    Quote Originally Posted by Matrix243 View Post
    to save it from the scuffs when it gets flipped over.
    guys i think i need some bright colour. or do you think i should do all black/candy red
    almost all assembly finished just need little detailing.
  24. #64
    sw Iowa
    326
    royal blue is always nice
  25. #65
    May 2009
    Colorado
    685
    I think flashy bright color will do well. Like a flying oasis! lol
  26. #66
    Long Beach, California
    5,630
    looking good maximus9, hows those stock 2.5 drive axle working for you? if you need the steel ones let me know... i have a set for you.
    Updates
  27. #67
    Aug 2010
    157
    i am still in the final assembly so dont knw how would they handle, the truck already weighs like a ton....
    steel axels i would love to have them.
  28. #68
    5,630
    I'll send it to you. I dont have use to it.pm me with your address again.
    for some reason its missing one drive cups.
  29. #69
    5,630
    I mailed the steel axle today (6/16), so you should recieve it by somewhere either monday or tuesday.
  30. #70
    Aug 2010
    157
    thanks mate....u have been grateful i really appreciate it
  31. #71
    Jun 2011
    24
    got a few updates on my truck.
    RPM skids and onboard temp gauge.
    trying to tune it lost 2 spurs on it. i dont understand where i am going wrong.
    [IMG][/IMG]
    [IMG][/IMG]
    Not sure if you want to or not but, if you drill a hole just below the muffler you can fit that plastic turn down under the truck. I puts the exhaust below the truck and keeps it much cleaner. You also don't have to cut out part of your shell to fit the end through anymore : )
  32. #72
    Aug 2010
    157
    updates....
    finished the assembly,check out the pics
  33. #73
    Aug 2010
    157
    waiting for the weather to cool down a little to check how it performs....
    the warthog body is still waiting for the paint options, hey can i use the normal paint which we use to paint cars.
  34. #74
    Mesa, AZ
    2,682
    no, you need to use lexan paint or it will flake off. ive tried without lexan paint, and i regretted it
    Hows that nitro taste on your electric?
  35. #75
    Sep 2008
    2,759
    You have to paint that Warthog (or Helios, or whatever they call it to avoid copyright infringement ) in some kind of martial paint scheme. If you live in the desert (which by those temps I would guess you do), paint it tan or desert camo. It would be a *beep*ing shame to ruin that body with candy red ! But I'm partial to straight olive drab myself for something like that. Can you believe it, they don't sell that in the rattle cans . I've an airbrush, but I don't have an air compressor so I need to get one. I got an $80 Badger double-action for $20 or $25! I figured I would squirrel it away until I got a compressor, and that was years ago. I had a 50% off coupon combined with other coupons and a certain % discount that was placed on everything in the store. Score!
    Then, you just need to fabricate a three-barrel Gatling gun turret for the back and buy a couple Halo action figures. I'd go with a Spartan in the drivers seat and two *beep* jumpers riding shotgun & on the turret.
    *Edit* - I forgot to say what I started out to say . Ditch the screws that come with the Tekno mount that are meant to hold the wing on, and go to the hardware store. I got some bolts that were the right thickness for the application that had hex heads (not hex driver heads, but actual hexes to fit in a socket). I then put the screws in going the opposite way, from underneath going upwards (do this with the pieces off the truck, then put them on the wing stays). You then put the wing and any spacers and washer on (as you can get any length screw you want, you won't have to worry about this), and pardon the pun but put a wing nut on to finish it off. The wing nuts will come right off with your fingers if you need to remove the wing in the field.
  36. #76
    5,630
    looking good maximus9, i like the paint job on that one. now its time for you to paint the warthog.
  37. #77
    Jun 2011
    Michigan
    704
    ditch the wing, only looks good on buggys to me
  38. #78
    5,630
    how could you not like the wing, you know, at 1st i did'nt like it either b/c its just adding more wieght to the truck but, now i like it alot that i end up putting all 3 of my truck with wings
  39. #79
    Louisiana but originally from Ottawa, Canada
    1,541
    Its really not about looks, its about practicality..But I'm probly like most where it grew on me and I love the look now. But your right it looks way WAY better on a buggy my body isn't a truck its kinda like the crowd pleaser.
    T-Maxx Predator 3.3
    Shockwave 36
  40. #80
    castalia ohio
    5,229
    the wings look better on a buggy yes but i didnt put one on there for looks. i kept messing up the head of my engine and i almost put a heavy roll cage on it just because i wanted to protect ti better. but you guys saved me from adding the weight, and waisting my money. thank you for that. i couldnt be happier with the wing. adds more stability on the ground, can control my truck easier in the air, and protects the engine. i thinkg every truck should have a wing but thasts just my .02
    someone should make like a cage so to speak that is really round. so that when you nail the brakes it will try and front flip and just roll over and keep going.
    Drag It!
