Buying the ezrun 60a 5.5t brushless set up I want to keep the system as cool as possible, I will be running 2s 30c 5000mah lipos, so can some one please tell me the safest gearing for this set up. Also when setting up the ESC what is the lowest volts a ******* lipo should go to still be in the safe range? Thank you all for your help. Also what is the max temp for the set up? I'm buying a temp gun and just want it safe temps to run all day.
