    Mamba monster esc and vxl motor ?
    Just wondering if I can run a mamba monster esc with the stock vxl 3500 motor. Will it cause problems over heating if I run 4/5/6s lipos ? The main reason I want to use the mamba is so I can run more volts for more power and longer run times. I just bash so no racing at all. Any body run a similar set up ?
    19
    I don't think the motor will handle 4S and up. It barely handles 3S.
    Lilydale, Victoria, Australia
    2,845
    ESC will work fine with the motor you will just need to change the connectors
    Stock motor does not like anything over 3s
    If you plan to run higher voltages you will need a different motor
    Cheers
    Slash Platinum
    So I'm better off with the castle 2200kv really then ?
    2,845
    Not sure why you want to run 6s
    4s with the right motor is good for 70 mph, plenty fast enough for bashing
    More power = less runtime
    Cheers
    Slash Platinum
