My 2wd slash started out as a 2.5ghz with the xl-5 and titan, and later I upgraded to the VXL. Ever since it seems like the trucks throttle "sticks" which I thought wasn't possible for an electric motor. Any idea how to fix this?
Center your trims, then let someone re-bind your 2.4 rx-tx, just to rule that out.
Then recalibrate your ESC per the manual, should be golden.
What have you tried so far? (and in what order?)
I have re binded the 2.4 before, but I put it away for the winter, and can't remember what else I tried
Your suggestion worked perfectly!!! The truck is operating great!!!Center your trims, then let someone re-bind your 2.4 rx-tx, just to rule that out.
