    Connecticut
    2,334
    Sun vs. E-Revo??
    Can I store my E-Revo VXL 1/16 in direct sunlight? Will this harm the electronics like a lot of things?
    Thanks
    9,768
    Why store it in direct sunlight? Everything will certainly fade and it runs in sunlight, doesn't it?
    Just make sure that you use SPF50 if you do.
    Jul 2010
    Hamilton Ontario Canada
    165
    My merv sits on a shelf that gets hit with tons of sun each day, along with all my other rc's. So it shouldn't be a problem... assuming it's indoor at room temp when stored.
    Mini Summit / Rally
    genXrated
    Guest
    Unless it gets as hot as a solder gun does(which I highly doubt), you'll be fine. May affect the tires over time and cause the to dry rot, but that's about it.
    Connecticut
    2,334
    OK, thanks.
