Results 1 to 14 of 14
    16
    D8 shock part number
    can anyone tell me the part number for the hot bodies D8 shocks and mounting stuff needed to put them on the slash 4x4? thanks.
    Lilydale, Victoria, Australia
    2,845
    You will need the following,
    D8 shocks (97mm) - HBS67296
    Shock standoff - HBS67202
    HB Grey Springs - HBS67446
    D8T long shock end (rear) - HBS67820
    Kyosho shock retainer (front) - IF346-05
    Losi 35wt shock oil - LOSA5225
    Cheers
    Slash Platinum
    16
    thank you very much.
    solomon, kansas
    421
    Yes Castle Creations is in KANSAS
    Aug 2008
    Auburn, PA
    628
    those are too long.
    If your really interested i can pm you a link for a set of 4.
    If i put it on the forum, they will be gone
    19
    Quote Originally Posted by kansas-slash2009 View Post
    I believe the front are but not the rear. Don't quote me on that.
    2,845
    Fronts in that set are 97mm rears are 112mm
    Cheers
    Slash Platinum
    16
    do i want 97mm front and rear? i know going by the big bore slayden set up the rears are 110mm with the front @ 96mm. just curious before i order the stuff. thanks.
    ps
    on the parts list i order 2 sets of each part right. dumb question i know but i wanna be sure im ready to go.
    2,845
    97mm for front and rear, additional parts (rod ends and shock retainer) change the length for you
    Cheers
    Slash Platinum
    16
    you are my hero.
    Sillion Valley, CA
    460
    if you are a racer, you might need all the list from Crusey to fine tune (front is lower, rear is higher, soft with grey springs and 35wt oil).
    If you are a basher and your truck is heavy with MT tires, large motor, then i suggest you to get the vorza rear shocks (very much the same as D8 shock, taken out of the vorza of course with orange springs - which is stift). You can get 4 of them for $55 shipped.
    I recently got one set, and could not be happier. I mount the front as is but use the outer holes on bottom and inner holes on top to get the truck lower.
    For the rear, i got the D8T long shock end (rear) - HBS67820 to raise it up a little.
    Other than that, i used stock mounts and some spacer laying around
    Sillion Valley, CA
    460
    1fstmr2,
    i don't have the 2nd slash but a quick check on them and I see that they both use the same shocks - regular or big bores.
    so sure the d8 or vorza 97mm shocks should fit on your 2nd slash.
    Here is a link to the mod: http://www.rcshortcourse.com/forum/t...-tutorial.html
    May 2010
    263
    Quote Originally Posted by Zero3 View Post
    Get big bores the hb d8 shocks suck
    Slash rocks!!!
    May 2010
    263
    I put big bores on my d8 lol
    Slash rocks!!!
