    899
    Stretched/torn/melted battery wrap suggestions
    After many charges and runs, one of my batteries has decided to start tearing/melting in the center. Any suggestions on what i can do to save this guy?
    Jul 2010
    England
    5,791
    I'd guess the cell directly under that melting has gone bad, resulting in a high Internal Resistance > hot hot hot!
    You would need to remove the cell and either replace it ( difficult due to the number of runs on the other cells already... ) or reconfigure the pack with one cell cell.
    7 > 6 cells isnt so bad really, can happily run 13 cells in total with no issue, though 6 > 5 will leave you with 11 cells total, still perfectly fine but you will loose a bit of speed and power so might need to drop a tooth on the pinion to gain some torque back...
    899
    rrgh thats frustrating. they are only like a month old batteries from promatchracing. com. too bad cause i heard such good things about them. i wonder if they'd give me a replacement
    Jul 2010
    England
    5,791
    They might well do if they are only a month old, send 'em an email with that photo and explain the issue- cant hurt to try & I believe they have a good rep for customer care..
    899
    will do. do you think its still safe to charge and run or is that a big no no?
    180
    Wouldn't risk it. If gets too hot, may cause serious damage to your vehicle's battery compartment/frame. Have also heard of bad charging situations that caused a fire.
    Jan 2010
    Central Wisc.
    360
    Quote Originally Posted by ArmyofDarkness View Post
    You would need to remove the cell and either replace it ( difficult due to the number of runs on the other cells already... ) or reconfigure the pack with one less cell....
    I spent last weekend doing that with a couple of Traxxas Power Cell packs (3000mah). Good practice for getting/keeping your soldering skills up to snuff.
