I would like to off road modify one of my ERBEs as good as possible
Both when it comes to durability and best performance for off road driving
So I have some questions after having read through FAQs here and the manual etc
are these mentioned below okay mods in combination with each other or should some be left out and do you have other tips
(2) #5656 Summit Driveshaft, long
(4) #5654 Summit CV Stub axle
(4) #5653 Summit diff output CV drive
(1) #5333R Extended Wheelbase arms
Is the (1) #5498 Sway Bar kit for racing on road at high speeds or will it also do justice to a off road set up
RPM suspension arms
RPMs rear suspension upgrade
Should I also install the long travel rockers and lift the ride hight in combination with the above
Should I install the steering upgrade also that comes with the truck or is that meant for high speed on road
thanks guys
