    55
    7-cell traxxas battery pack voltage?
    What should a healthy 7 cell 8.4v traxxas pack fully charged read?
    Thanks, Luke
    Jul 2010
    England
    5,788
    They can read upwards of 9v usually, but that peak/ freshly charged voltage will soon drop back down to nearer nominal voltage- dont be too concerned about nimhs or nicads reading higher than rated.
    21
    Why do the Nimh read higher than their rated voltage?
    665
    Lipo do the same. There is the nominal voltage or resting voltage then there is the charged voltage.
    Sent from my Transformer TF101 using Tapatalk 2
    2,215
    Nimh 7 cell will usually read about 9.6v when they are fully charged.
    Lipos do the same thing.
    15,999
    Here's a graph of a normal NiMH pack charge showing volts per cell.
    The drop occurred when the charger switched to trickle. Still, end voltage was over 1.4 volts per cell. If you aren't ending at 1.4V/c minimum, your cells are weak or damaged IMO.
    Alt-248 on the number pad =
