+ Reply to Thread
    557
    hellow help quikly with soldering!~
    I got like some solder on the top of the connecter on one of the peices and a little past the line... is it fine?!
    TX
    276
    It might be ok, but you might want to just heat it up and move it back just a bit. Just to be safe
    recalculating...
    563
    The connector is fine if it can be assembled correctly and plugs into the other connector without problems, if the wire is securely soldered to the connector and there is no place where + touches -. If solder is in the wrong place remove it, hope this helps if not post pics if you can
