Thread: tire wobble??
    kelowna, B.C, Canada
    44
    tire wobble??
    so my 5603 e revo the tires wobble when i hold it in the air and accelerate.
    now they wobble to the side but it looks like alittle bit up and down???
    i have checked every thing and its all tight.
    is this normal???
    Jul 2010
    England
    5,791
    It is fairly normal sadly. Check it isnt just the tyre thats been glued slighty ski-wiff to the rim firstly by swapping wheels around. If they are all glued unevenly or slightly on the wonk, then you'd need to unglue the tires and re-do them properly ( hurrah for factory tire gluing... not ). If how ever the wheel itself feels wobbly on the stub axles, then you may need/want to invest in some better hexes, or use some thin washers/ shims between the hex and the outer bearing to remove any play that is present.
    180
    Had similar problem when I bought new Proline street rims and tires. Was good up until 3/4 throttle then things got... bouncy. Proline RMA'd the tires. Haven't got around to putting the new set together yet.
    LHS suggested getting a model airplane prop balancer for $20, then adding mirror putty(?) to the low spots. Youtube has some videos on this. Seems like in modern manufacturing they can balance a set of rims and tires out the door.
    Jun 2009
    W Monroe, Louisiana
    1,991
    balancing FTW!!!
    261
    I balanced mine yesterday.. It took 5-10 grams on each wheel.... MT badlands on Mugen wheels.
    Well worth the 30min`s it took.
