Results 1 to 12 of 12
    22
    how often to refill shock oil on Slash 4x4 VXL?
    Hi all, I've had my Slash for a month and played about 10 times or so... feeling the shocks are stiffer than brand new and not quite dampening. Am I suppose to refill the shock oil that soon? How can I tell that a refill is due?
    thanks
    Dec 2008
    Melbourne Aus
    1,925
    Take the shock off, remove the cap and check the oil level, refill if needed, 5 minute job
    Cheers
    Slash Platinum
    SCT MMP / 2400kv
    54
    But unless the shocks are leaking you shouldn't have to top them up.
    Check your suspension for binding. Make sure everything is smooth and flappy with the shocks off. Also inspect the shocks for damage.
    22
    So you mean normally the shock oil shouldn't be dried up so soon, right?
    Ok, I will open them up and check the oil level... if I will need to refill, what oil to use?
    1,192
    It is likely not your shocks but your stock axles binding.
    37
    Quote Originally Posted by Tallguy905 View Post
    right on, disconnect your shocks and move the arms up and down to check for any binding. bent shock shafts and dirty pivot pins would also cause stiffness.
    low oil will cause looseness.
    Aug 2010
    Fob Warhorse Iraq
    146
    i check my shock oil once a month when i do my monthly tear down on the truck
    54
    Quote Originally Posted by kdog View Post
    And did you ever have to refill a non-damaged damper? I guess not.
    Aug 2010
    Fob Warhorse Iraq
    146
    not all the way maybe half way but that can be from the cap not being on tight enough now it does get dirty so you need to change it out to protect the seals
    Aug 2010
    UK
    1,251
    if you over fill then some might leak from the bottom seals.
    Ashburn, VA
    15
    try this it may be some of the problem
    http://www.youtube.com/watch?v=yzqmK...e=more_related
    Slash 4x4
    22
    This is great advice... i should look into cleaning those shafts. Thanks!
