    Dec 2006
    4,382
    Lightbar, available when?
    Hey Guys,
    This is a question for Traxxas, when is the roof lightbar (#7287) going to be available???
    Thanks!
    Daniel.
    Jun 2010
    Miami, Fl
    6,731
    You can make it work, so far I did the front lights, but here on the forum there is a guy who put lights on top.
    Dec 2006
    4,382
    I already did, the electronic part is not the problem, the problem is that I don't like to drill the stock roof lightbar because it looks ugly that way...
    Dec 2006
    4,382
    Heads up, it's available now for $11, just bought two (omnimodels), I'll post pictures soon...
    Dec 2006
    4,382
    Just one pic for now, will add more later...
    First thoughts, after 3 years of waiting, I have to say I was impressed when I received it...
    Front white 5mm LEDs have a nice plastic back cover so you won't see the little board or the solder...
    They also included two rear 3mm red LEDs!!! Instruction sheets are also included in English and French...
    Everything is wired up but be careful, you will burn the LEDs if you plug it into your receiver... 3.3v max I guess...
    This is because Traxxas uses a lightning module to step down the voltage directly from your battery...
    The lighting module goes on the other servo hole, this is very similar to my power strip idea, I'm glad they used it...
    Same for the rear red LEDs, I used the front light bar on the rear on my 1/10 Summit...
    So, really nice work, I'll install them on my yellow Summit and post pictures soon...
