Is LVC absolutely needed for running 2s lipos in parallel (which i plan to use)? why?
Explain me what is LVC for?
Thanks!
Thanks!
LVC detects when your battery is almost out of voltage or whatever, and it cuts the power before you over-discharge your battery. Over-discharging a lipo can ruin it or signifigantly reduce the life of the battery.
ohh, so thats what is it, do i need to get it or is it included in ESC?
That's an option included on your esc (red led nimh, green led lipo mode), you have to select lipo mode if you are going to run lipo in your car if not the batt will be drained and damaged. If you have red led on your esc, turn the esc on, then press and hold the on/off and keep it until it beeps and the light switch from red to green, it is on your manual.
EMAXX-FLM, Summit 1/10, HPI Savage Flux XL.
oh thats right, i forgot about it, so ESC in lipo mode can handle 2s lipo in parallel?
sweet, do i need to change the pinion to speed pinion?
oh ok, does it affect speed? because i heard that speed pinion slows car down
it does but you won't notice the difference still pretty fast. Now that you are going to use lipo you will notice the improvement.
good, i bet it will improve my merv very well
