Results 1 to 11 of 11
Thread: LVC for merv
    48
    LVC for merv
    Is LVC absolutely needed for running 2s lipos in parallel (which i plan to use)? why?
    Explain me what is LVC for?
    Thanks!
    148
    LVC detects when your battery is almost out of voltage or whatever, and it cuts the power before you over-discharge your battery. Over-discharging a lipo can ruin it or signifigantly reduce the life of the battery.
    48
    ohh, so thats what is it, do i need to get it or is it included in ESC?
    Jun 2010
    Miami, Fl
    6,731
    That's an option included on your esc (red led nimh, green led lipo mode), you have to select lipo mode if you are going to run lipo in your car if not the batt will be drained and damaged. If you have red led on your esc, turn the esc on, then press and hold the on/off and keep it until it beeps and the light switch from red to green, it is on your manual.
    48
    oh thats right, i forgot about it, so ESC in lipo mode can handle 2s lipo in parallel?
    Jun 2010
    Miami, Fl
    6,731
    Quote Originally Posted by GSTROCKS View Post
    yes it can
    48
    sweet, do i need to change the pinion to speed pinion?
    Jun 2010
    Miami, Fl
    6,731
    I will do it, it helps to run cooler.
    48
    oh ok, does it affect speed? because i heard that speed pinion slows car down
    Jun 2010
    Miami, Fl
    6,731
    it does but you won't notice the difference still pretty fast. Now that you are going to use lipo you will notice the improvement.
    48
    good, i bet it will improve my merv very well
