    Jul 2010
    Orange County CA
    109
    running with 2 batteries vs 1 battery
    anybody running 2 at a time? Will the extra weight make it easier or harder to drift?
    Jun 2010
    Miami, Fl
    6,731
    I tried mine with two not a problem.
    central pa
    311
    im running two batteries not a problem
    Jul 2009
    Ontario, Canada
    11,145
    The car is actually designed to be run with a single battery on the left side. If you read the manually completely there is a section that talks about weight balance and how the car has been balanced at the factory to run just a single battery. My experience supports this. With 2 batteries the car would drift one way and spin out the other EVERY time... it was annoying. I took the right side battery out and the problem went away. Jakey also noted this in his comments about his car... as have a few other members. You certainly CAN run 2 batteries at a time... but it handles better with just one.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Dec 2004
    3,656
    ... You certainly CAN run 2 batteries at a time... but it handles better with just one.
    When done correctly, light weight is always right!
