Results 1 to 3 of 3
    163
    Ball bearings in the steering assembly
    I just purchased the ball bearings part number 5114 to replace
    the stock plastic bushings part number 2545 for the steering assembly. However when I try to install them they don't seem to fit (slide over the shaft). The
    measurements are the same as the stock ones (4x8x2.5mm) so I don't
    understand why this wouldn't work. When forced on they act like a spring, moving the servo saver right or left. Has anyone else run into this problem?
    Aug 2009
    Calgary, Alberta. South.
    130
    Yes, with my Merv. I gave up trying to hone/sand the post, or find a bearing that fits as well as the plastic seat.
    Oo
    Spike 553
    Jun 2010
    Miami, Fl
    6,731
    The bearing for the steering is 5x8x2.5. It's a tight fit but fits.
