This new 4wd pede is my first 4wd truck and it will not track straight under even medium accelaration. My 2wd vxl pede has no problems and I'm pretty good @ adjusting camber and toe. The 4x4 vears left and right.. just almost unmanagable on flat pavement. Could the differential be binding? Also I run 2s and 3s lipo on my 2wd and the motor/esc stay generally cool but the 4wd heats up real fast.. any Ideas or is it normal for the 4wd to track bad if it's a little slippy out?
If I can hold my hand on either one...then it's cool enough for me. I'll play around with everything over time.. my biggest concern now is the Low voltage detection on the 4x4. Sometimes it activates within min of plugging in a new bat. I have to unplug or even just turn off the esc to re-set, then it's fine for a while. I have no similar probs with the same esc/motor on the 2x4..
Now I see its actually the truck.
