+ Reply to Thread
    29
    Suitable micro servo's
    Call me crazy, but I drove my Summit into a lake last weekend, to clean off the mud
    It went in with no problem, but it lost signal when it got below the waterline
    I had to use a rope to get it above the waterline, and it drove out of the lake easily.
    I killed two of my microservo's though (rear diff lock, and the gear servo), so I need to order new microservo's. I'll probably order 3 or 4, because I expect the front diff lock servo's to die very soon too (judging the other two )
    Anyone know about suitable waterproof (not necessarily lake-proof) servo's. Maybe even some stronger ones than default?
    Jul 2009
    727
    Hi,The micro servo's are adjustable using the white screws in the back of the transmitter.Well in the 27 mhz,and the 4 channel 2.4ghz
    29
    Thanks for the tip, mine actually died though :P
    I also see I mentioned micro servo's, but ofcourse, the Summit has sub-micro servo's.
    Traxxas #2065 http://traxxas.com/products/parts/servos/2065
    As far as I can see Traxxas is the only manufactures that actually produces these waterproof sub-micro's, so... Is that my only option?
    If so: any tips to get them even more waterproof?
    Jan 2007
    regina sask, canada
    2,344
    i use these to replace the micro servos that quite on my summit all you have to do is make the hole bigger so the screaws fit and i used liquied electronic tape to water proof it
    http://www.hitecrcd.com/products/dig...hs-5055mg.html
    if your not breaking anything get more air
    29
    How do you waterproof the opening for the gear on top?
    Jan 2007
    regina sask, canada
    2,344
    all i did was put liqued electric tape on it were the cases goes together and it worked fine i have had it all the way under water with no problems
    Sep 2009
    Victoria B.C Canada
    4,260
    Quote Originally Posted by _eLMo_ View Post
    Pull the top off and some grease not to much up wear the gear comes through the case
    Mountains cant stop me
    they have tried
    1,535
    proj 002: The Funky Gecko
    Man, Use Common Sense!!
    Jan 2007
    regina sask, canada
    2,344
    i had to post this pic
    do you think this is a good enough test to see if their water proof lol
