Results 1 to 2 of 2
    Jun 2001
    Advance,Nc,USA
    103
    Post PORTING TRX PRO .15
    Im porting my engine out in about 2 weeks and i need to know how many rpms i need for the dremel cause nitrorc said make sure you have enough rpms to cut through and so i wanna know how many rpms do i need or whatever the dremel term is for how fast it goes. I saw one that has wither 15,000 or 1500 today and i dont remember which one but how fast does the dremel need to go and please give me a DIRECT link to the dremel and bits u used to port ure engine out. Thanks in advance
    Jun 2001
    cincinnati, ohio, usa
    83
    Post
    If i know what porting the engine is, then i did it last night, along with making the holes in the baffle bigger. I think porting the header is just taking a dremel and grinding out the header to make the opening the same size as the one on the engine. i had to cut out a new cardboard thing to replace the old 1 that i accidently broke removing the header. As rpm's r concerned, most dremels start out at 5,000 and go up to 30,000. I stayed at 5,000 the whole time, but it tends to slow and stop, i only did cuz my parents were asleep. 15,000 rpm's shouldnt give u a problem, it is much esier than it sounds.
