all .15 crankcases universal????????????
I have a .15 trx engine with a busted crankcase. Will a tower hobbies .15 crankcase fit???????????????!!!!!!!!!!!!!!?????????????????? ??!!!!!!!!!!!!!!!!!! And what is the proper installation process for the high speed needle
I don't think itll work. The ports probably won't match up, also the crank, piston, sleeve, con rod, and backplate/starter shaft all need to perfectly match up. If all this works, then you have yourself a running engine !
But not likely
-Mike
www.angelfire.com/mi/mikem
- You may not post replies
- You may not edit your posts
Forum Rules
