+ Reply to Thread
    Jan 2001
    grand rapids,MI.
    663
    Post the stampedes rear tires!
    Is it just my truck or is the stampedes rear tires pigion toed?(Both pointing in towards the front of the truck).And if this is a common problem then how do I fix it?If it is'nt then who do I have to take it up with to get it rited??
    Jan 2001
    So Cal
    8
    Cool
    The rear tires are supposed to be like that on the nitro $tampede in order to help keep the truck from spinning in circles under heavy throttle. Basically for control purposes.However if you would like to straighten them out, you can, all you need is Traxxas part #2797 (0-degree suspension mounts)Have fun Drive hard.
    LIKE A ROCK CHEVY4LIFE
    Jan 2001
    largo,florida,USA
    192
    Arrow
    I got those 0 degree suspencion mounts and it takes out alot of degrees out of the toe in but you still have alot.but good thing is when you have that lesser amount of toe in when you make tooo tight of a turn instead of fliping over it goes out into a spin,hey youve got to admit when it is far away i would rather just puch the throttle and go on again instead of going after it and turning it back over right side up.
    Jan 2001
    Bridgewater, NJ US
    315
    Post
    I'm gonna get those cause my truck flips all the time when i turn sharp and i have to loosen my suspension.
    ...We HaVe IgNiTiOn...
    Jan 2001
    grand rapids,MI.
    663
    Post
    I'm really with rc maniac on the punching it over running to it in time to get it flipped right again,Whats the stock degree on the rear a arms?
    Jan 2001
    Bridgewater, NJ US
    315
    Post
    I'm not sure but i think it's a lot
    Jan 2001
    grand rapids,MI.
    663
    Post
    I know because it wobles back and forth at full throttle and asphault!
    Jan 2001
    Brigham,Utah U.S.
    15
    Post
    I just recently purchased the nitro stampede used for 200.00 from a local hobby shop.I asked them about the tow-in on the rear tires and they also said that it would not be able to stear or handle very well if I tried to straighten them out.But,it seems to me that it would handle better at high speeds if it didn't have to fight against the back tires all the time.My truck seems to wobble alot especially at top speed.Bearings instead of bushings seemed to help a little but not alot.Can I straighten them and get better handling?
    Jan 2001
    Oxford,CT. USA
    116
    Cool
    my truck came like that and u fix it by setting the toe in this case give it a little toe out
