Results 1 to 8 of 8
Thread: Pinion trouble
    Bambo87
    Guest
    Exclamation Pinion trouble
    I have trouble when i race my 4-tec because my pinion gear keeps coming off. i run a trinity p2k if any one could help please do!
    Jared
    bobby
    Guest
    Post
    are u sure u put it in right?
    is the grub screw on the flat side of the motor shaft? make sure it is and tighten it. this should keep it on .
    hope i helped
    Bambo87
    Guest
    Post
    that is the way i run it but it doesnt work just falls off again
    Jan 2001
    decatur
    28
    Question
    u yea
    Jan 2001
    England
    1,354
    Post
    tighten up your grub screw !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!
    are you thick or somthing?
    Bambo87
    Guest
    Post
    it is as tight as it goes
    Jan 2001
    Mercer, PA, USA
    168
    Post
    Tell us some more information and we might be able to help you some more.
    -Zee
    Jan 2001
    Florida, Gauteng, South Africa
    42
    Post
    If your grub screw's allen key head is stirpped, you might have to resort to what I do: Put a drop of superglue on there!! You won't be able to change pinions in a hurry, but it keeps the pinion in place, and when you want to remove the motor, a light tap or two on the drive shaft works to free the pinion again. If you wanna go that route...
