+ Reply to Thread
    Feb 2002
    298
    Question How do I use after run oil
    When I put the drops into the carb do I take the glow plug wire off and turn the motor with the easy start to circulat the oil??
    I can fix anything! wheres the duck tape?
    Jul 2001
    PA, USA
    1,828
    1. take off the air cleaner
    2. add 3 or 4 drops into the carb
    3. turn the motor over by hand using the flywheel (turn it over a few times
    4. put the air cleaner back on
    www.ovrp.com
    RC Turnbuckle Jr. Tazz R/C owner's Avatar
    Sep 2001
    Hartland, WI
    9,644
    Just to add a little...
    It's best to put the A-R-O in a closed carb, then open and close it a couple times to keep that lubed... then follow steps 3 and 4...
    I love the smell of nitro fumes in the morning!
    Jul 2001
    PA, USA
    1,828
    i knew i woudl forget something
    www.ovrp.com
    Nov 2001
    cleburne texas
    745
    you can remove the blue wire and spinnit over with the ez-start if you want to eather way works.
    I do what the voices in my head
    tell me to do.
    Mar 2002
    Vancouver, Washington
    61
    IMPORTANT?
    I never used after run oil! Will my engine die quicker than usual especially because I run my engine on extra-lean settings?
    It's a brid! It's a plane! No, it's my Nitro Sport jumping across the street!
    Jul 2001
    PA, USA
    1,828
    well leaning on "extra-lean settings" will damage the motor by itself. even if you did use a-r-o you would still damage the motor fairly quick. a-r-o just lubes the internal parts of the motor, since nitro can gumm up. that is how a-r-o helps engine life
    www.ovrp.com
    Sep 2001
    Hartland, WI
    9,644
    The a-r-o is also a WD (water displacer) nitro fuel will attract moisture, and that moisture will rust the steel parts of the engine (crank shaft, wrist pin, g-clip, starter shaft, one way bearing, glow plug)
