Tranny Out after only 5 tanks of fuel?
I ran only 5 tanks of fuel on my new Traxxas and it quit pulling. Running on short grass (football field) and on running track during break in. Spur gear is transferring power in to the trans/differential, but no power out to the shafts. Diff yokes are tight. Any ideas. Have not torn down yet...
i am havign the same exact problem!!
only i have gallons through this bad boy... its 3 years old, but when i dug into the tranny here is what i found,
the steel topshaft gear is actually a press/friciton fit onto the shaft with a small cross pin.. my pin snapped and the gear is actually spinning on teh shaft... y doesnt traxxas just machine the gear?
thast a good question i cannot answer... hint-traxxas....
the part is 4193
I had that problem as well... turned out all the gears in my diff on one side had no teeth left on em.
dave
Ease up the slipper clutch a little might help....After you get it fixed
diff. gears been there done that. stay off hard top till its really broke in thats what i did. i had to fix a frieds he broke his in in a parkinglot big oops about tank 4 and it was toast
i had the same prob i had to tighte my slipper clutch tighten it untill it gets hard to do no all the way then loosen it i quarter turn hope i help
get em boys
- You may not post replies
- You may not edit your posts
Forum Rules
