+ Reply to Thread
    Jun 2001
    quebec, canada
    1,355
    engine idlying problems
    my engine will idle good but then in 2-3 secs all of a sudden the idle goes slower.
    does anyone know whats wrong?
    Keep the spirit of R/C alive
    r/c's and skateboarding, my anti-drug
    Apr 2001
    renton, washington, usa
    1,165
    Check your low speed needle, irragular idle is often caused by it being set incorrectly.
    born 'n' bred bottle fed small block mopar
    Look whos back :) for today anyway.
    Jun 2001
    quebec, canada
    1,355
    ok thanks ill check it out when i get my new spur
    striped it again
    Oct 2001
    LUTON/ENGLAND
    1,877
    your idle screw might be set a bit slow and when it goes to its poistion it slows it down after 2-3 secs and or your plug is ok but not full power.
    also your not using 5% nitro are ya cause if you are then thats why.
    david wright
    take it to the red line
    Junk is something you keep for years and then throw it away 3 weeks before you need it.
    rustler rules the rc world
    aim is wdave13 plz
    nitro_dave15@hotmail.com msn
    i dont like the new desert storm why? cause power is nothing with out control
    Oct 2001
    Sumter, SC
    1,323
    you say that after 2 or 3 seconds is slows.. does it continue to slow and then stall? If so, this is usually caused by your engine "loading up" with fuel.. the low end needle is set too rich. It should be able to idle with no problems for at least 15 seconds... and after that 15 seconds, your engine should not bog when applying throttle...
    is2!
    Jun 2001
    quebec, canada
    1,355
    i using 20% powermaster. and i could go for a new plug
    my idle is perfect. it will idle through the intire tank without me reving it up a bit. ive already done it.
    but do you think its maybe cause when i let off throttle theres still a lot of pressure in the tank and in 2 or 3 secs the hard pressure goes away?
    Oct 2001
    Sumter, SC
    1,323
    Have you pulled the air filter, reved the engine and released the throttle and actually watched what the carb does? If not, I suggest you try that..
    What it sounds like to me is that the throttle is closing, but it's gummed up a bit and not closing fully, but after a few seconds the pressure on the spring from the servo in conjunction with the vibration of the engine causes the throtlle to close slightly further..
    is2!
