+ Reply to Thread
    Mar 2001
    Baltimore, MD, USA
    94
    ok guys, I'm close...Just a little more help starting....
    I replaced the pull start, got a new glow plug, put everything back to factory specs and can finally get the pede to start. BUT now it revs really high and I think its the low end screw cause it bogs just a little until it gets over the low end speed hump and then takes off. Problem is, once it starts, it won't stay running unless I up the trim on the idle, at which point it takes off like a madman and wheelies all over itself. I know I'm close....any thoughts??????
    Thanks!
    Tim
    Jan 2002
    267
    make your low end needle a lot richer it is way too lean
    Jan 2002
    erie,pa
    317
    adjust your idle srew mine did he same thing.
    Registered User
    Oct 2001
    159
    check all ur throttle servo setup and makesure it is set exactly right
    Mar 2001
    Halifax ,Nova Scotia, Canada
    243
    Put the low end needle (len) flush with the throttle arm, now make sure the idle is set correctly. The opening in the throat of the carb should be like 2-3 mm I think. Its in the manual anyway. Once you've got that all set up it should run pretty decently.
    Now when you tune it all up for good performance make tiny changes at a time, 1/16 th of a turn on either the low or high needle makes a huge difference. Once you have made the slight adjustment run it for at least 30 secs to see if it worked. This gives the engine enough time to cleanout all the extra fuel or bring in more fuel. (depending on if it was lean or rich) I used my radio trim nobbs to set up the idle as I went so that it wouldnt stall but make sure you dont use the brake since it will stall if you do. Once you figure the idle is set properly by the radio you can adjust the set screw to make the change permenant.
    Later,
    Rittles
    Marshal mike505's Avatar
    Feb 2001
    Old Town, Florida
    6,308
    Cool
    Use this page for your carb settings.
    http://www.traxxas.com/support/howto...buratorpro.htm
    Make sure your servos are centered. Here is the page for that.
    http://www.traxxas.com/support/howto...adiosystem.htm
    Hope this helps.
    Pain is Temporary, Pride & Achievement is Forever.
