Results 1 to 11 of 11
    59
    Bellcrank bearings
    I was wondering if anyone has put bearings in the stock plastic bellcrank. Or if it can be modified ( drilled ) to make the bearings fit. Mine still works fine I just don't like bushings. Buddy of mine bought the rustler and it came with bushings on the wheels. They only spin like three times and stop. My slash came with bearings and i didn't think the tire was ever gonna stop spinning. Just lookin for a cheap way to tighten up the steering cause for 6$ you can buy 4 5114 bearing compared to 35$ aluminum bellcrank
    Jan 2010
    Tyrone, Central PA
    512
    Rustler VXL's have bearings in bellcranks.
    HK Brushless Summit!!!
    59
    Are they the same part # for the plastic bell crank or do you have the part# so I can compare it. I have the 2wd slash no vxl 4+4 or anything
    Germany
    1,552
    You need 5x8x2.5 bearings. They are a direct fit, just pop out the bushings and put in the bearings.
    59
    Sweet thanks don't have a part number do ya
    Jun 2009
    Sweating my butt off in FL!
    828
    www.Avidrc.com and search for the size you need.
    Neu 1512 1.5Y Rustler 23/50 geared 3S powered
    Feb 2008
    SoCal, USA!!
    728
    I have these, and love them. Combine them with the $12 4x4 bellcrank, and you will have steering nirvana.
    59
    Is the 4wheel drive stronger or does it turn farther?
    Jun 2009
    828
    Quote Originally Posted by bigdodge150
    Its more sturdy, comes with bearings (from what I've read), and has a built-in servo saver.
    Feb 2008
    SoCal, USA!!
    728
    Does not include bearings (at least not in the 6845 kit), but the ability to remove the awful on-servo saver and run a regular arm is worth it all by itself. Much, much sturdier than the stock 2wd belllcrank. It's also a direct drop in kit.
    Dec 2006
    4,381
    +1 on the 6845 kit... Take a look at the pictures I took:
    http://monster.traxxas.com/showthread.php?t=523221
