    Jul 2009
    Ontario, Canada
    11,145
    Help me understand the width of this truck
    Peter V says the width is the same as the 2X4... but im having trouble figuring this out. It has slash 4X4 arms... which are the same width as the REAR Pede 2X4 arms... and it runs 4 front offset wheels. If you put front offset wheels on the rear of a 2X4 pede, it gets wider...
    So is the 4X4 wider overall than a 2X4? Is it the same width as a 2X4 with a protrac kit? It should be if it does use slash 4X4 arms and 4 front offset wheels.
    Is this thought process correct? Does it make sense?
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,057
    I am just thinking out loud here but it makes sense to me that with the 2x4 you have the width of the transmission between the arms making it wider where with the 4x4 you only have a diff between the two arms making it narrower.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Jul 2009
    Ontario, Canada
    11,145
    So, is the slash 4X4 wider than a slash 2X4... I guess its not is it. Its the same but the 4X4 has wider arms.... so this must mean what your saying is exactly right. The arms are wider, but the distance between where they mount is narrower. So what do we do? Jato I guess? Anyone tried widening their slash 4X4?
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Jul 2009
    Ontario, Canada
    11,145
    Just searched the Slash 4X4 forum and found this. They are both out of stock, and aluminum... I dont want aluminum arms so I wont buy them... but maybe someone will come out with something different? At least we know its out there to be done.
    RC Solutions Slash 4X4 Wide Arms
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Jun 2010
    Springfield, Ma.
    3,356
    This is a good chance to try the wheel extensions. Seems to be the easy option. Just keep some extra baerings handy.
    Sep 2008
    2,122
    i would try >this< i think it would work the only thing is i wonder if it will be just as durable?
    Race-bred SSC 4x4
    Durango DEX410
    15,374
    FWIW, the Slash 4x4 is almost 13 inches wide, outer edge of tire tread to outer edge of tire tread wearing front Stampede wheel & tires. Since the relevant parts are identical between it and the Stampede 4x4 VXL...
    Alt-248 on the number pad =
    Dec 2006
    4,377
    Quote Originally Posted by pavmentsurfer
    Yup, I took some pictures for you... It's exactly the same...
    That's the rear part of my second Slash 4x4 with Stampede VXL front tires... Which I'm going to convert to Stampede 4x4 as soon as the parts are available on eBay...
    Jul 2009
    Ontario, Canada
    11,145
    Great pics daniel... thanks so much man. That pretty much sums it all up doesnt it.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
