Page 2 of 6 FirstFirst 1234 ... LastLast
Results 41 to 80 of 207
  1. #41
    Jun 2009
    The Rotten Apple
    874
    Quote Originally Posted by BAC5.2
    Here's mine. I really like the stock wheels/tires, but they wear pretty quickly on high grip tarmac. I got these today, and they'll probably wear really quickly and not slide very well. But we'll see tomorrow!
    Sorry for the crappy cell-phone pics on my pool table...
    Please keep all images to a size of 640 x 480 pixels or smaller.
    -ksb51rl
    I am using the same thing and they are awsome on my freshly paved street.
    Only difference is I have hpi tires on the rims now as they wore out in about 4sets of 3s packs, I was driving it full throttle most of the time.
    havnt failed I just found 1000 ways that wont work
  2. #42
    6
    There was a fellow last winter on one of the other forums that made his own snow tires using basic straight pins, pushed through from the inside and then cut to length on the outside. He made a video of himself and a friend running at night on an ice rink. I must have worked, as they left snow-roosts behind their cars.
    Quote Originally Posted by eemmaaxxxx
    If it is sheet ice, rubber just won't cut it! Literally I was thinking about this the other day, and providing the pins are short and the heads are fairly small I can't see why it wouldn't work. This is a 2009 WRC snow/ice tyre. I think it would be near impossible to replicate this because the pins would have to be tiny. Having said that, I've never seen a TC tyre.
  3. #43
    Jan 2010
    584
    Quote Originally Posted by RcPocketRocket
    I've noticed that they get SUPER sticky after you wear the glaze off. From that point on, they are pretty awesome... and still wear fast.
    I love the look, though. Much more than I expected I would.
  4. #44
    Pittsburgh.PA
    30
    Has anyone worn out a set of the stock Traxxas Rally tires?
    Mine are showing signs of a little wear with only about 40 or so minutes of run time with the stock battery.
  5. #45
    Jul 2010
    Hamilton Ontario Canada
    165
    Quote Originally Posted by stburr91
    I've got a week on the stockers and they are showing some wear... not that i'll be using them much anymore of course. Drifting loses it's fun pretty quick, i'm really loving the high grip factor of my hpi rally tires. Also found out pretty quick that I didn't glue them properly this morning when letting a friend WOT it causing a tire to fly right off lol Even with a low profile compound that fit super snug it still managed to fly off pretty quick! Note to newbies, scratch the paint off the area to be glued on the rim! lol
    Mini Summit / Rally
  6. #46
    Jun 2009
    115
    What brand wheels/tires fit the Rally? Pretty much standard 24mm TC stuff? I want to get some drift tires and HPI wheels. Do HPI wheels have the right offset and size?
    Thanks
  7. #47
    May 2006
    DENMARK
    1,394
    Yeah they do if you use the zero offset
    Morten
    Morten SnoopMaxx
    3906 ROCKSTAR Makita
    c",)
  8. #48
    Aug 2010
    UK
    1,254
    does anyone make the hard plastic drifting tires that would fit this.
  9. #49
    Jun 2009
    115
    Quote Originally Posted by SnoopMaxx
    Morten
    Thanks. So 26mm wheel/tires fit with no clearance problems?
  10. #50
    Jul 2009
    Ontario, Canada
    11,145
    Ive fun for a total of about 45 minutes and my tires have worn down %25 with %75 remaining. I ran a set of HPI X pattern tires and in only 20 minutes they were worn at least %30...
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
  11. #51
    Dec 2002
    Port Hadlock, Washington
    197
    Time to start casting your own I guess.
  12. #52
    Jun 2009
    115
    Just downloaded the manual and it says the stock wheels are 26mm and have a +4 offset. From what I read here, zero offset wheels are recommended. Has anyone actually tried zero offset wheels on the rally? Just making sure before I place my order for TC wheels.
    Thanks.
  13. #53
    Jan 2010
    584
    Whatever the Nitro 4tec uses seem to fit perfectly.
  14. #54
    Jan 2009
    kingston ny
    301
    Quote Originally Posted by turok
    Well there's alot of different 26mm wheels and tires out there, and diff offsets too.. I just ordered my rally today and it should be here Friday , and I have some drift rim/tires from my other car that I'm going to test out...
    hmmm what did i break now
  15. #55
    RC Turnbuckle Jr. streetdemon's Avatar
    Jun 2003
    The home of the brave....
    3,119
    Quote Originally Posted by pavmentsurfer
    Noticed the same thing with my buddies Rally. Stockers seemed to wear fast through the first few packs and then seem to wear a little less quickly as of now, but still a good amount for the weekend. We threw on an old set of tires I had from when I was racing TC (probably 7 years ago now) and they gripped well, but the little bugger tore them apart (they were pretty worn already), so next was the foams which seemed to fair well. They don't have great grip but not bad either, seems like a hard foam tire may be the way I actually end up going with mine. Lasts pretty long.
    Some like R/C's that are fast, others like nitro
  16. #56
    May 2006
    DENMARK
    1,394
    Quote Originally Posted by DaDOOD
    Thanks.
    I measured the backspacing on some of my TC wheels. And they are +7mm offset from the center
    A zero offset would make the car 14mm wider ??
    So is a zero offset TC wheel in reality +7mm offset ??
    This is how I calculate offset
    Backspacing = 20mm
    Width = 26mm
    Center 26/2 = 13 mm
    20-13 = +7mm
    And +4mm offset
    4+13 = 17mm backspacing
    If this is correct then using my stock TC wheels would make the Rally 6mm narrower
    Morten
    Morten SnoopMaxx
    c",)
  17. #57
    The Netherlands
    143
    The way you are calculating offset is the way we do it in real life. A wheel with 50 offset (or ET50) will be sticking out less than a wheel with 25mm offset (ET25, the latter sticking out 25mm more).
    However with rc wheels, I think they do it a little different. I think that when they talk about +4mm offset, that they mean it will stick out 4mm more. Not sure, but I will find out soon, since I ordered some wheels with +3mm offset
    But, I don't think the traxxas wheels are +4mm offset. When I take my digital caliper and measure the distance from hex (not inside hex) to inner wheel bead, it's 13mm. The wheel wide is 26mm, that makes me think these are 0 offset wheels. My schumacher sorex tires with wheels are 0 offset and they have the same specs.
    If however I measure inside the hex, then it's 17mm, which is 4mm offset from center :S
    The same wheel with 0 offset would make them stick out 4mm more according to the first picture.
    This is getting confusing...
    The question is, what is the right way to measure? Inside the hex or not, cause that adds 4mm...
  18. #58
    May 2006
    DENMARK
    1,394
    That's correct PIR3lly
    My Rally VXL will (hopefully) be under the Xmas tree
    Morten
    Morten SnoopMaxx
    c",)
  19. #59
    May 2006
    DENMARK
    1,394
    Just found these tyres from Conrad international in Germany
    Morten
    Morten SnoopMaxx
    c",)
  20. #60
    Sep 2010
    211
    What offset is correct for this car... HPI makes offsets in 3 6 and 9... I have a set of 9 offset wheels I bought for another project and they stick out along way... but the stock Rally wheels look like they may be 0 offset. Is this true? Just need to know what to buy.
    3-is fine and will work on the Rally
    6-is right on the fenders front or back, maybe adding some negative camber with clear the tire from rubbing the body.
    9-is just to much and the tire will stick out of the body
  21. #61
    106
    Correct = neg-3 clears fine, neg-6 rubs the fenderwells
    Quote Originally Posted by CESAR View Post
  22. #62
    106
    Going to have to order some of those, as long as the rubber compound isn't too hard.
    Quote Originally Posted by SnoopMaxx View Post
    Morten
  23. #63
    May 2006
    DENMARK
    1,394
    Well there's only one way to find out
    I might get a set of these as well
    Morten
    Morten SnoopMaxx
    c",)
  24. #64
    106
    Morten
    If I knew they were halfway decent I'd tell you to order two sets, I'll buy the other from you.
    They look like a great general purpose tire.
  25. #65
    Sep 2010
    211
    I'll post pictures of my setup's tomorrow
  26. #66
    28
    Morten
    Just an FYI, these also come premounted on that website. They do look pretty good though, should hook up well in the loose stuff.
    Traxxas Rally Car
    3.3 Maxx
    Xray XT8
    TC3
  27. #67
    Dec 2002
    197
    Just tried Slash tires today. Works much better than stock for ice and up to 1/2" snow.
  28. #68
    106
    Quote Originally Posted by Greenboy View Post
    I've read where others have tried the Slash tires, and found the car rolled over too easy.
    But for your purposes, running in the snow and on slick ice, they should work fine. Any heavy treaded or lugged tire should do the trick. I have some HPI Rally tires and they work well too.
  29. #69
    13,158
    double post...
  30. #70
    13,158
    I like the look of the hpi x pattern.
  31. #71
    106
    Found these tire studs made by NewEra on thetoys.com
    http://www.thetoyz.com/cart/thetoyz_...cat_name=RC18T
    Quote Originally Posted by eemmaaxxxx View Post
  32. #72
    Dec 2002
    197
    Quote Originally Posted by robs4rc View Post
    I also tried fairly smooth cement. Didn't traction roll, but didn't slide easily either. All the rough surfaces are covered with snow currently.
  33. #73
    Jul 2010
    165
    Trying out some street/carpet rubber on some new rims, and i'm seeing how running a zero offset will work out with the added traction.
    http://i40.photobucket.com/albums/e2...C/IMG_5177.jpg
    http://i40.photobucket.com/albums/e2...C/IMG_5167.jpg
    Once again, keep all images to a size of 640 x 480 pixels or smaller.
    -ksb51rl
    Mini Summit / Rally
  34. #74
    13,158
    really behind the curve on these mini's. looking on ebay, and found these and am wondering if they are too big for the rally:
    http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
    look at the second pic in this listing, looks like they could possibly fit the rally.
  35. #75
    May 2006
    DENMARK
    1,394
    That looks like standard MERV size wheels
    way too big for the Rally
    Morten
    Morten SnoopMaxx
    c",)
  36. #76
    13,158
    in the second pic of the second link it shows a pic of them mounted. looks smaller than the stock merv tires. Also says the merv tires will not fit the rims and the tires will not fit the merv rims in the first and third link. I was just hoping as those tires look great. oh well...
  37. #77
    May 2006
    DENMARK
    1,394
    Oh I see it now
    However they don't give any info about hight or width
    Morten
    Morten SnoopMaxx
    c",)
  38. #78
    Jun 2003
    We-Go, Chicago, IL
    2,705
    Wouldn't a bunch of short bits of piano wire work for that too? Maybe cut a strip into 1/8" pins and jam them into the tread of the tires and drop a bit of CA to hold them in place afterward.
    Those street tires look a lot like the old 2.0 Buggy Road Hawgs from Proline
    Aw, Biscuits!
  39. #79
    13,158
    the listings say 2.2 tires. I am confused. I will try to contact the seller to get the o.d. of the tire. Could someone measure the stockers?
  40. #80
    Jun 2008
    windsor ontario
    96
    Just finished about 4-5 hours of rippin up the indoor shagg at LHS.I'm new to onroad so was completely stock till LHS owner threw some Jaco blues at me and said"try these" WOW!!
    Was no longer drifting around corners man was it a blast!!
    .........gosharpie97.
    Traxxas Rally
    Hpi Blitz ESE
    Jammin SCRT10
    Ve8
