Results 1 to 14 of 14
    Jun 2003
    Estes Park, CO
    917
    Rally Shock Part Questions
    Just a few questions bout the shock parts for the rally. Not sure if anyone knows yet but who knows?
    1. The piston valving, are the holes smaller than the revo/slash valving?
    2. The springs for the rally, are they stiffer than the revo springs?
    Dye-no-mite Pow-er Go Fast, Wirrrrr Screeeech BOOM
    Putting the water on the hot stuff
    9,702
    I was just looking at the manual and cannot remember. You can read the manual and look at the exploded views and compare.
    Dec 2006
    4,382
    According to the parts lists and the manuals:
    Rally
    2 x 0.5mm holes + spacers
    2.89 green/white springs (front and rear)
    60wt silicon oil
    Front differential 50.000W silicon oil
    Rear differential 30.000 silicon oil
    E-Revo
    2 x 0.5mm holes
    1.89 green/red springs (front and rear)
    40wt silicon oil
    Front and rear differential 30.000W silicon oil
    Slash
    2 x 0.5mm holes
    30wt silicon oil
    Edit: hope I got it right, there's no info on the stock springs for the E-Revo/Slash on the manual... Also, the piston valving should be different on the Rally, but looks the same on the parts list...
    Jun 2003
    Estes Park, CO
    917
    Well, atleast the springs are stiffer. Gonna get a set to throw on my revo, though i heard the valving was smaller aswell. Guess the stock shock pistions will stay in then. Also I know the slash springs are softer than the revo springs, can't give you numbers on it though.
    Jun 2010
    Miami, Fl
    6,731
    Nice job danielhr77, do you have any info on spur gear and motor pinion?
    Nov 2009
    UK
    838
    i'm waiting for the stiffer springs, too, but while i was waiting, i decided to try the double tan springs and 60wt oil, and i'm actually well pleased with the results.
    i was going to test 100wt, and 100wt mixed with others, but 100wt and the double green springa and it was very slow to bounce back.
    @ RC-Fan: the manuals for the rally are posted on the traxxas site. i have no reason to believe they won't b different to the slash stock gearing, considering the wheels are the same size.
    ... oh, and sorry about your wallet
    May 2006
    DENMARK
    1,394
    The specs for both list the Overall Drive Ratio:7.32:1 (stock, out-of-box)
    However the Slash transmission PDF list's the pinion to be a 31t (2431)
    and the Rally to have a 26t pinion (2426)
    Morten
    Morten SnoopMaxx
    3906 ROCKSTAR Makita
    c",)
    Dec 2006
    4,382
    Quote Originally Posted by RC-Fan
    Sure! Here you go:
    E-Revo
    Pinion 28t - #4728
    Spur 50t - 7046
    Slash
    Pinion 31t - #2431
    Spur 50t - #7046
    Rally
    Pinion 26t - #2426
    Spur 50t - #7046
    They all share the same spur but different pinion...
    Nov 2009
    UK
    838
    ^the slash without the updated bulkheads came with a 45 tooth spur gear - i have one. i wonder why it's changed?
    Jun 2010
    Miami, Fl
    6,731
    Quote Originally Posted by Wiggy Fuzz
    I might be buying a year old slash, with plans to convert it to rally, how do I know if it has the updated bulkheads, what part # should be the replacement?
    Dec 2006
    4,382
    I started a thread about that sometime ago...
    http://monster.traxxas.com/showthread.php?t=508932
    I don't remember now, but I think it's the same part #, you have to be lucky and get the new one...
    Nov 2009
    UK
    838
    A few hobby stores are phasing out the original bulkheads. It's not a big part, to me the original is no different (and in my mind, breaks easier), so if you have the older style ones, change it if/when it breaks and don't fret.
    With the originals it as one less screw to worry about, and you didn't need to remove the left front upper a arm to take that apart...
    Jun 2010
    Miami, Fl
    6,731
    got it !! thanks danielhr77 good thread
    Dec 2006
    4,382
    Found it!!! These are the part numbers for the bulkheads:
    Old rear: 7029
    New rear: 7029X
    Old front: 7030
    New front: 7030X
    Sorry for the off-topic!!!
