    May 2010
    Wisconsin
    1,064
    Keep Blowing Diffs
    Alright, in the past few months i have blown 3 diffs. This last one went out while going slowly around a dirt oval track. The truck wasnt even used that much since i last replaced it. However the last time all i did was replace the gears.
    So what should i do. Im thinking about ordering a all new diff, and a tranny case. Maybe its warped or something and the outputs are coming out at an angle.
    Im getting really tired of tearing the thing apart so i want it to be done this time. My friend said he never blew a diff in it the entire year and a half he had it. and he was running the same motor I am. (CC 4600 on 2s).
    Slash 4x4 MMP-HV 5.5
    Slash Sidewinder SC 3800kv
    Germany
    1,552
    Maybe your slipper is too tight? My diff still looks like new after 9 months, 7 of which were on an ezrun 4000kv brushless set.
    Feb 2009
    Upstate, SC
    429
    think you might get a better response from the 4x4 Slash section. This is 2wd. I blew 3 diffs also within 2 months. called traxxas and they are sending me some "upgraded" parts. think it might have something to do with the bearing that is in front of the CD. my CD was moving like 8mm from front to back. Traxxas said it shouldn't have any play in it. I'd give them a call and let them help you out or at least point you in the right direction.
    Quote Originally Posted by Arakon
    I'm about 99.9% sure he is talking about the 4x4 Slash. (look in his signature) you are refering to the 2wd Diff, which is like a iron horse...lol I havn't had any problems with my 2wd Diff in the Mod or Stock Slash at all. The Center Differential replaces the Slipper on the 4x4.
    Youtube Search- Tommy Wooten RC
    Germany
    1,552
    According to his signature, the CC motor is in his 2WD.
    Feb 2009
    Upstate, SC
    429
    ok...i was going by his name and his signature. And I don't see how he keeps blowing 2wd Diffs....?????? Never had 1 single problem with mine and i beat the crap out of those trucks on the track. Now the 4x4 Center Diff I have had a TON of problems out of. Guess we all get a little confused sometimes.
    RC Turnbuckle Jr. streetdemon's Avatar
    Jun 2003
    The home of the brave....
    3,119
    I actually jsut had mine go on me last night. It was weird, over a year on 2 rustlers both with original diff and then this one goes out on me after a few weeks, but in a slash. This one was always more open feeling than the others so maybe some heavy grease or something tacky could rectify my problem.
    Some like R/C's that are fast, others like nitro
    Dec 2009
    Central Ohio
    293
    I have not had a problem with any of my diffs, and I own a slash (almost 3 years), a bandit/rusty(2.5 years), and 2 other rustys(2 and 1 years, respectively). You might want to try re-greasing everything and replacing your bearings.
    Traxxas Slash
    Losi XXX
    Most of a Traxxas Bandit
    El Sobrante, Ca
    7,058
    I have 2 slashes. No problems with the diffs. Have had both over a year! One is 2 years old.
    May 2010
    Wisconsin
    1,064
    The first two went because of the venom cvds but now this one just went out with almost no pressure on it at all. Id be willing to bet my transmission case is bad. since the venom cvds really hit it hard going off jumps since they were too long. and when i put it back together with new gears it ground a little bit.
    i need a new tranny case anyways. the gear cover holes are stripped out. I will replace the 2 bearings also.
