+ Reply to Thread
    Aug 2010
    Livermore, CA
    144
    Tires that last?
    I know this has been covered several times, as I have spent literally hours reading old threads about tires, but I am wondering if there is anything new out there in.
    I burned up my Anacondas in one weekend, which wasn't surprising as I run on asphalt only and was just having fun with the car (burning out, donuts etc.)
    I've been running Jacos for a little bit now as I have only been experimenting with high speed runs, but I threw on a set of Proline Road Rage II's (2.2's) to go mess around in my favorite parking lot.
    Where I run is smooth blacktop (it's a UPS loading dock area), and I was pretty careful with these tires. In one afternoon of running, there is already a completely bald strip on about 1/3 of the tires in the rear.
    It's getting expensive just to keep tires on this thing!
    I lessened the camber a little in the rear with the Traxxas piece (I believe it goes from 4 to 3 degrees with this). Should I get the New Era piece that will set it to 0 degrees?
    Are there any new tires out there that somebody has found that last?
    Jul 2009
    Puerto Rico
    173
    For me the Panther Slicks (soft) had better grip than tha Jacos (in normal asphalt) and last longer. But Jacos doesn't ballons, better handling, etc. And adjust your rear camber to 0 degree.
    http://cgi.ebay.com/NEW-Panther-Burn...3#ht_682wt_911
    Here are some proof of the tires:
    http://www.youtube.com/watch?v=BdEYO...eature=related
    RC Turnbuckle Jr. streetdemon's Avatar
    Jun 2003
    The home of the brave....
    3,119
    This may go against what most do, but is there a way to swap your front carriers for electric carriers, that way you can run hexed wheels on all 4 corners and rotate the tires.
    Some like R/C's that are fast, others like nitro
    Aug 2010
    Livermore, CA
    144
    Not a bad idea, I'll look into that. It's always been frustrating that you can't rotate the tires on the Jato.
    Nov 2009
    LA, California, USA
    418
    with proline wabashes you can
    Instructions are for cheaters
    Jan 2010
    Montgomery AL
    950
    Quote Originally Posted by streetdemon
    Seems to me I read something about doing just that. BUT, I have no clue where I saw it. Sorry. I bet someone here will have an answer for you/us.
    US Navy retired, now - FAA air traffic controller
    Nov 2009
    LA, California, USA
    418
    Apr 2010
    St. Louis, Missouri
    689
    Quote Originally Posted by ineedjatohelp
    I did that same mod and i'm extremely happy with it. I think if you add some washers behind the bearings on the inside, it eliminates more of the steering slop.
    If your interested, i posted a revised version of the mod (can't take credit for the original idea) for how to do it with aluminium parts, just in case you like the added bling.
    http://monster.traxxas.com/showthrea...ler+caster+mod
    Are the tires supposta to blow off going into 2nd?
