    May 2010
    Ontario, Canada
    270
    Question Thick Battery Holder?
    My question got buried in another thread, so I'll ask it in a separate post:
    I just bought an SMC 3s lipo, 8000 maH. It seems about double the thickness of a "standard" lipo.
    Would this battery hold down extension work for it:
    http://www3.towerhobbies.com/cgi-bin...?&I=LXUVZ8&P=7
    I can't find dimensions on it.
    Don't buy lipos from a "scratch and dent" sale.
    May 2010
    USA
    666
    Quote Originally Posted by phlegm
    I'm pretty sure it will as I have the same one and it accomodates two 2s packs on top of each other with room to spare.
    Aug 2010
    Pewaukee, WI
    63
    Located on page 12 of the manual.
    Battery Compartment Specs:
    • 166mm (6.54") long x 49.5mm (1.95") wide
    • Height with stock strap: 23mm (.91") or 25mm (.94")
    • Height with Part #5827X options battery standoffs: Up to 44mm (1.73")
    Note: There is some flex with the battery strap. It is possible to fit slightly taller batteries in the compartment.
    May 2010
    Ontario, Canada
    270
    Thanks folks - the battery is 40mm high, so should be perfect!
    El Sobrante, Ca
    7,106
    I have that part on my 11.1 3s 5400mah. It is a fat battery. It has room for a bigger lipo. It should work just fine for you.
