    Aug 2009
    Spruce Grove, Alberta
    1,552
    heavy duty knuckles
    These look like really heavy duty knuckles and should fix up the wheel wobble at the same time. I believe they should fit a Summit. Not sure if they are worth the $$$, but could be worse I suppose.
    http://traxxas.com/forums/showthread.php?536733
    Jan 2010
    Tyrone, Central PA
    512
    The stock knuckles are a problem?
    HK Brushless Summit!!!
    3,092
    ouch!!! i love tekno stuff but at $40 you may as well go with full aluminum. besides usually the wheels themselves protects the carriers, washers/shims can be use to remove the slop, and wobbling adds character.
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Aug 2009
    1,552
    Quote Originally Posted by StreetShaker
    not really, I have had to tighten them up a few times from normal wear, nothing lasts forever. I mostly just like the adapter concept.
    Quote Originally Posted by noir522
    scratches add character, the wobble has driven me nuts since day one.
    Ok, I just noticed they come in pairs. So ya way to expensive anyway.
    Victoria B.C Canada
    5,185
    Quote Originally Posted by quadiak
    I hear ya thank god the 23mm hubs fixed that.I just noticed on one of my knuckles/axle carriers the outer bearing goes right in to the back bearing.The lip that prevented that has mysteriously disappeared.Oh where could it have gone The weird part, the bearings are fine
    Mountains cant stop me
    they have tried
    Aug 2009
    1,552
    Quote Originally Posted by jamann
    three of the four knuckles on mine lost that lip when i changed all four axle shafts. I should check and make sure they are still good, maybe I actually need new knuckles
