+ Reply to Thread
Thread: Run time
    182
    Run time
    Anyone know the rough runtime of a stock summit on the included 2 packs?
    Also dutatrax 5000 DTX if ya know.
    29
    About 20-25 minutes on the stock packs and 45-60 minutes on duratrax 5000...
    Summit (#5607)
    Sprint 2 Drift Sport (#761)
    182
    wow thats 2-4x what I expected
    My stampede thats 1/3 the weight and much more effecient with 1 5000 pack does not last 1 hour.
    HS guy told me 10-15 mins on a pair of DT 5000 packs.
    **Saw a 4 or so year old boy at the park with a summit. I had a remote car that only went in a "J" shape at his age !
    Aug 2009
    Spruce Grove, Alberta
    1,552
    really depends how you are using it, if you are bashing you will get 15-20 on the 3000 mah and 25-30 on the 5000 mah, crawling will do much better.
    http://traxxas.com/forums/showthread.php?536733
    May 2010
    Colorado
    534
    Like quadiak said, it depends on how you drive it. With my stock summit batteries I got about 45 minutes on my summit a few times, but other times I only get about 20 minutes. Crawling a lot will give you a much longer run time. Lots of high gear running will give you a shorter run time. Don't worry though, even with a lot of high gear running the run time is still pretty good. I have some orion 4500mah's and they run significantly longer than the 3000mah's do (if that helps).
    Why can't other people share my opinions?
    182
    Will be in low mostly I think.The crawling and locked up stuff seems fun.
