will these work? http://http://www.thetoyz.com/cart/t...201/16%20REVO#
your link is jacked, but those work on the merv, so they would also work on the slash
how wide are you trying to go? if you want to, you can convert it to a merv and be much wider
Love how Noobs ask a ?, then say you're wrong
If you are trying to keep a fairly normal stance and just get slightly wider you can use 3mm/6mm/9mm offset 1/10 touring wheels with rally tires (which grab better than stocks anyways) and you wont have to make any adjustments to the suspension...
The Bashing Grounds
Ross M.
5-Pointer!
going wide as possible so going to make it a merv. Thanks
