Results 1 to 31 of 31
    Aug 2010
    So Cali
    18
    How to make E revo vxl drift?
    I was wondering what i would need to do to make my MERV drift. Would i only need to get new tires or do i have to buy a special steering servo?
    Feb 2002
    4,613
    servo is fine, just need drift tires, my truck can drift on stock tires depending on the terrain
    Jul 2009
    Douglasville GA.
    36
    The best way is to get some HPI t-drift tires, lock the rear differential, lower it to get rid of some body roll and practice,practice,prectice.
    Mini VXL e-revo
    x-ray t1 drifter
    Losi MRC
    Dec 2008
    Gettin' Lucky In KY
    3,876
    I was just messing around with some of the wheels and tires from my E10 Drift car the other day and they bolted right up no problem. They are HPI T drift tires and the HPI black 10 spoke wheels. They look a little small on the truck but whatever.
    Wheels that I have
    http://www3.towerhobbies.com/cgi-bin...?&I=LXAWL2&P=7
    Drift Tires
    http://www3.towerhobbies.com/cgi-bin...&I=LXSGF3&P=ML
    I do suggest getting a heat gun to get those tires on the wheels. They can be a pain because the tires are really not made of a rubber compound, they are more of a PVC type hard plastic. Also you do not have to glue them. They fit so tightly on the wheels that it's really not required to glue them. Some guys will put a few drops on them, but seeing as how tight and how much of a pain they can be to get on and off the wheel, I skipped the gluing.
    champlin mn
    540
    how long do those tires last??
    Big Block KB
    ERBE Tekin rx8
    MERV Basher
    Jun 2010
    Winnipeg, Manitoba, Canada
    457
    Long enough that you probably won't even need another pair. I thought the same thing when I first ran my t-drifts. But don't worry it's not like they'll wear down to the rim. HPI T-drifts are highly recommended plus they add some sweet chrome to your ride
    99%er
    Aug 2010
    So Cali
    18
    So pretty much all i have to do is buy the HPI drift tires?
    Jun 2010
    457
    yup, and lower your ride height(adjust your shocks) and lock your diff. Can somebody link or show a good tutorial on how exactly to lock your diff? Im not sure and i dont want to ca glue the wrong parts
    99%er
    Jul 2009
    Douglasville GA.
    36
    there is a few ways (1) silly putty. Take the rear diff out clean out all of the oil that is in it and pack as much silly putty as you can into it then reinstall it into the truck. The nice thing about thai way is if you want to go back to an open diff you can, just clean out the silly putty and add oil. (2) JB weld. Agian remove the read diff , clean out the oil, pack it with the jb weld and quickly reasemble the diff, let it dry than put the truck back together. The down side is once the jb weld is in thats it no going back, its locked forever, if you want to go back or strip a gear you will need to buy a whole diff assy. Its that easy.
    Mini VXL e-revo
    x-ray t1 drifter
    Losi MRC
    Dec 2008
    Gettin' Lucky In KY
    3,876
    Quote Originally Posted by AKlaib2
    You have to get wheels that they will fit on as well. Like the ones I posted a link to above.
    Jul 2009
    Douglasville GA.
    36
    Use these link
    Mini VXL e-revo
    x-ray t1 drifter
    Losi MRC
    champlin mn
    540
    would grease lock the diffs up?
    Big Block KB
    ERBE Tekin rx8
    MERV Basher
    Jul 2009
    Douglasville GA.
    36
    could use this too locker
    Mini VXL e-revo
    x-ray t1 drifter
    Losi MRC
    Aug 2010
    So Cali
    18
    Thanks.
    Jul 2009
    Douglasville GA.
    36
    I see that you are in Cali maybe thia can help too hyperdrift
    Mini VXL e-revo
    x-ray t1 drifter
    Losi MRC
    Jan 2010
    Ukraine
    576
    the real drift cars are rear wheel drive.
    just remove the front part of center driveshaft to exclude front differential.
    and you'll drift on any tires
    look here:
    *************************/v/#27
    My mini E-Revo.net and the BIG ERevo.net
    Dec 2008
    Gettin' Lucky In KY
    3,876
    Quote Originally Posted by Evgen
    look here:
    Possibly but that is not what I would technically call "drifting" in those videos. The guy is just flipping it around and pretty much just doing donuts and not doing any long drawn out drifts.
    Yes in real full scale drift cars they are RWD. But there are many factors that are different. Weight biases are completely different compared to an RC car and they are specifically setup for drifting.
    In most RWD RC cars (example the Rustler or 2wd Slash) the motor and transmission components are in the rear of the vehicle making it rear heavy and almost impossible to control when setup to drift. Now in the 4WD touring drift cars, you'll see the motor and gear box most likely mounted near the center or the front of the vehicle, and the 4wd being added for extra stability in longer more pronounced drifting maneuvers. It's' all about weight placement. Now in a 2wd RC if the weight placement is correct, it would be possible to still drift the car, but it would be alot more difficult than if it was 4wd.
    Jan 2010
    Ukraine
    576
    i actually didn't tried to drift on that video need way more free space with smooth asphalt for this
    i just showed that mini revo can be rwd too
    Jan 2010
    Ukraine
    576
    and also it's almost impossible to slide on that tires. their grip on asphalt is too high.
    when i wanna slide i put this ones on:
    [IMG]*************************/t/IMG_8435.jpg[/IMG]
    Oct 2010
    Short stroke your shocks and get wider wheels, and use 3s or 4s. You can drift anywhere even with 4 wheel drive
    Feb 2013
    Maryland
    140
    Quote Originally Posted by jrdk View Post
    This may sound stupid but I'm a nebie to this hobby. How do you lock the rear differential
    so cal
    9,244
    Try 7381 traxxas
    Feb 2013
    16
    Quote Originally Posted by 007A99 View Post
    Read the thread
    holliston massachusetts ( 20 miles West of Boston)
    98
    Cover any tires in duct tape and you will be sliding all over the place
    Mar 2013
    47
    i put duct tape on mine and it doesnt drift VERY well but better than without it
    i want really long stable drifts
    196
    I seem a video where the guy cut PVC pipe that was the same diameter as the tire and then he slipped them over the wheels
    Apr 2013
    85
    Armor all the tires - my son was having a blast last night
    Feb 2013
    Maryland
    140
    Quote Originally Posted by RZSmerv View Post
    Last time I tried drifting my merv, it resulted in a napped chassis and front bulkhead
    Mar 2013
    47
    i put duct tape on my tires, didnt really drift
    im driving in a parking lot so i may have to lock the diff and try again
    i also bought a roll cage too
    163
    Pics of the HPI drift tires on erevo please!! How do you lock the rear differential?
    ^^Summit Kawasaki Edition and E-revo VXL^^
    Mar 2013
    47
    Quote Originally Posted by traxstar View Post
    perhaps something called looking at the thread
