+ Reply to Thread
    Mar 2009
    Rosarito, Mx
    46
    In-cabin air cleaner
    So, every time I drive my car, the A/C smells soooo bad like dirt and a weird smell, and tried to find out that the filter is removable from behind the glove-box, I opened it and found noting, I drive a 96 Nissan Maxima. I've searched another car (Honda Accord09) and found it, someone told me that older cars don't come factory with the filter, or maybe I'm searching the wrong place.
    I expect the unexpected.
    May 2007
    TEXAS
    623
    Have you tried you're local mechanic? I looked on Google for a few minutes but couldn't find anything about it.
    Sig edited as a one time courtesy.
    NC
    RC Turnbuckle Jr. streetdemon's Avatar
    Jun 2003
    The home of the brave....
    3,119
    If you plan on doing other repairs to the car get a haynes manual, they can be found for like 15 bucks and are worth WAY more than that, for situations just like this. Sometimes the cabin filter is accessed through the engine bay, they are always in different places, some are a total pain to get to.
    Some like R/C's that are fast, others like nitro
    Jun 2003
    3,119
    Easiest way to find out is call a local napa and ask them if they have one in stock. They can tell you right away if they had one in your car or not.
    In a burning building
    8,712
    You can check online on auto parts centers (such as O'reilly, AutoZone and others) under your vehicle to see if they have a part number for a cabin air filter. If so then it should be behind the dash. Maybe some of them put them behind the engine in front of the passenger too. A Haynes manual, as mentioned, is great too.
    When I worked at an auto parts/hardware store, I bought a spray that I could spray into the air intake under the windshield and through the vents that would essentially get rid of the mold that created the musty smell. It has worked great. You may want to try that or something that eliminate mold.
    Jun 2003
    3,119
    If all else fails, get some OUST, turn the AC on high and "recirculate" and spray down in the vents like double G explained and let it get sucked through. Empty the whole can as fast as possible and get out, leave it all closed up for a while running so as to not kill the battery, then go out later and shut the car off and open the windows.
    May 2010
    St. Louis MO
    277
    Napa carries the in-cabin air filter for my 2001 Altima. I installed it as a retrofit and it works great. From your description it sounds like they're in the same location, behind the glove box. Installation was pretty simple.
    VXL Slash, Castle Slash, XL-5 Rusty, 2002 Pede
    Apr 2009
    Australia
    127
    Quote Originally Posted by streetdemon
    Spray down the vents with the fan on high probably better to spray into the air intake that is above the passenger foot well it may have a blocked evaporator drain hose causing a build up of water in the ac box,easiest way to tell if its blocked is to park on concrete with ac running ,a small puddle of water should appear on the ground on the passenger side of the car behind the front wheel after a couple of minutes or so,hope this helps
    Trav
    Dec 2009
    MI
    2,502
    Personally, instead of a Haynes manual, I would go straight for the real thing and get the repair manuals created by Nissan and used by Nissan dealers for your specific model and year.
    http://cgi.ebay.com/ebaymotors/Nissa...sQ5fLiterature
    ◄▲▼► SUMMIT ●○●○● 2 RUSTLER VXL's ●○●○● MERV ◄▲▼►
