Page 3 of 3 FirstFirst 1 2 3
Results 81 to 115 of 115
  1. #81
    144
    My new toy for now
    ^^Summit Kawasaki Edition and E-revo VXL^^
  2. #82
    144
    Quote Originally Posted by quadiak View Post
    I had to update once again
    Motor : Novak 7.5 HV(sensored)
    ESC : Mamba Max Pro
    BEC : CCBEC
    Spur\Pinion : 12/68
    Batts : 2 SMC - 2s 9000 Mah Lipo in series(4s 9000 Mah 28C)
    Speeds : 32 Mph(calculated seems close)
    Run time : 1 1/2 Hrs bashing - 4-5 Hrs crawling/hiking(estimated)
    Wheels/Tires : RPM Revolver/Losi Claw MT's
    Body : Proline 2007 Silverado
    Suspension : LT with Double orange springs front and rear, 70 Wt shock oil
    Radio : Traxxas Link HO (modified for 3 position 3rd and 4th channels)
    Servo(s) : Hi-Tec 7980(front) - Hi-Tec 7955(rear)
    Programmable Digital Components : MMP, CCBECm, Hi-Tec 7980, Hi-Tec 7955t
    Custom : Front mounted motor, front mounted ESC, 2 water proof boxes, Servo saver spacer, Single front steering servo, 4WS(front and rear), TRX front toe links.
    All of the exposed electronics are listed as water resistant, everything else is mounted inside the water proof boxes. I believe it to be quite reasonably water tight. As far as swimming goes, it is certainly not as water proof yet as I would it like to be. but I'm sure I will test it at least once
    Sumbot Build thread
    would i be able to get that much battery life if i were to get the same batteries and use them on my stock Summit ? Sorry for the noob question
  3. #83
    Oct 2007
    1,394
    No, you would not. Because he's using a Brushless motor, it's way more efficient than the stock brushed system - especially since he's got it geared for only slightly faster than stock. I'd guess you'd get about 1 hour bashing, 2-2.5 hours of crawling, though, which is still pretty awesome!
  4. #84
    24
    Well, here is "Big Red"
    This is the truck mounted camera. Its made by Swann and was 90 bucks. Its not an hd cam, but it does very well.
    The rear steering setup
    The on\off switches for the roll bar lights and emergency flasher bar
    the full back shot
    Roll bar lights
    Emergency flasher bar
    and here is all the wires, switches, and a 6-cell traxxas 2200mah batter. Itried to get it all into the gas tank. it didnt work out very well for me. i will try to clean it up later on.
    and a shot of the camera compared to the truck
  5. #85
    1,539
    Necromancer
    proj 002: The Funky Gecko
    Man, Use Common Sense!!
  6. #86
    1,539
    I see several new builds on the way -
    POST THEM UP HERE
    so they wont get flushed and forgotten down the Traxxas archives.
  7. #87
    3
    I got my summit 2 weeks ago. Can't wait to start my build. There's lots I want to do. Keep pics coming
  8. #88
    Upstate,NY
    16
    Dewalt-14.4 w/ Kershaw Designs 7000mah Lipo's
    Savox steering servo's 500 oz/inch each.
    18 Nichia LED's 28 Lumen each total of 504 Lumen ran off a 11.1v 3s 1200mah Lipo.
    Chassis, Exo-cage and A-arms coated with Herculiner
    Stock tires in photo's b/c I was headed rock crawling. Also have Trencher X's and Mudslingers. (Mudslingers have every other lug removed glued together in pairs and glued to the sidewall congruent with the existing shoulder lugs.)
  9. #89
    1,539
    DESIGNER/ CREATOR : Krohpit
    motor : stock titan 775
    ESC : stock evx2
    Spur/pinion : 68/14
    WHEELS/TIRES : stock canyons 6!!!
    BODY : custom extended summit body
    Suspension : Stock
    Radio sys : Stock tq4
    Bolt ons : center cvd
    Custom : custom 6 powered wheel setup, custom transfer case with inverter gear, custom double sided differential
    Comments/ quote : This is my Summit. All wheels actually turning under power. I will make foto report about build .
    two rear diffs are on a "Y" harness
    n my 6X6 e-revo 1/16 not used invertor gear (gear in the third diff change from left to right - very simply) but in the Summit use lock diff and was additionally problems. Next step - change all CVD to metall and change motor+ESC to Mamba. I few idea about change body... Maybe Tamiya 1/14 King Hauler booth... Maybe made Summit extended from two body
    ORIGINAL BUILD THREAD :
    http://traxxas.com/forums/showthread...mit-on-youtube
  10. #90
    22
    My Summit.
    All stock accept for tires, wheels, and LED's in light bar.
    Original Body!
  11. #91
    1,539
    Anymore creativity out there?
  12. #92
    Germany
    72
    creative enough?
    http://traxxas.com/forums/showthread...Summit-Projekt...
    Summit & E-Maxx
  13. #93
    1,539
    OUTSTANDING
    Dual esc? roll cage? that a lot of work.
  14. #94
    Jan 2002
    278
    custom brazed roll cage
    mudslingers with every other lug cut out on tech 5 wheels
    ham sandwich mod
    full build thread here
    onboard and offboard videos of me running it at a full scale offroad park
  15. #95
    83
    Here's my summit. I narrowed a set of Axial wheels and star cut the foams and put on a set of 40 series Mudslingers. After frying 2 775 motor and losing the LVD on the EVX2 I put in my castle mmm 2200kv system. Here's some pics of my mods.
    NOTErized!
  16. #96
    83
    Quote Originally Posted by Tmaxxed View Post
    NOTErized!
    And now I waterproofed my Castle ESC.
    NOTErized!
  17. #97
    26
    Got my rok loks on, other then that its still stock for now..
  18. #98
    1,539
    bump up the jams
  19. #99
    67
    well my summit is nothing compared to some of the others posted here, but i am proud of what i got.
    mine is all stock including the traxxas nimh battery's only thing iv added was a fpv system.
    immerson rc 500mw 5.8g tx
    immerson rc reciever
    immerson rc 600 vtx camera
    power filter (not a bec)
    and a tiny 11.1 1100 mah lipo to power the gear,
    and a 2007 chevy crew cab body from my MGT.
    my summit next to my other truck,
    before the fpv gear!
  20. #100
    windsor ontario
    38
    my oil cooled mamba monster summit ...i like to play in the water previously had 2 wp sc8 esc that blew up in the water so i decided to make my own waterproof container ,,, ive been running the mamba monster since day 1 in this oil filled box , over 4 months now ,the heat transfer is amazing my temp sensor doesn't even reach 110 degrees just hard o get it initially sealed , the mamba is mounted to a big heat sink in the aluminum container which also dissipates heat, have some 1watt lights a winch and GMADE piggyback shocks which id recommend to anyone , these shock have amazing compression nd rebound , the tires always stay planted rc4wd rock crushers on narrow wheels and big joes 2 8000 mah batteries , lots of other mods ,,, btw my summits a little beat lol nowhere near perfect haha
    front bumper broke off the night before
  21. #101
    Jan 2002
    278
    Quote Originally Posted by skunkmann View Post
    this is beautiful. all summits deserve a life this full.
  22. #102
    83
    Here's my summit, 40 series Mudslingers on axial bead locks that I narrowed. Castle monster mamba (waterproofed) 2200kv. Traxxas cvd center shafts. Lots of fun!!
    NOTErized!
  23. #103
    83
    NOTErized!
    Oops, I just realized I posted this already.
    NOTErized!
  24. #104
    278
    put in the hpi brushless set up.. super fast and programed to crawl well with drag brake..
    Not much traxxas left on this thing...
  25. #105
    83
    Quote Originally Posted by markman View Post
    How are you liking the brushless? I put my castle mmm 2200kv in my summit and was expecting it not to crawl at all but it does pretty good. Cogs just a little from a stop but still works great. And it's an absolute blast to drive now.
    NOTErized!
  26. #106
    278
    Loving the brushless! Before the castlelink it was just too much power. I toned down the punch, adjusted the power and brake curves and put in 50% dragbrake. All things not possible with evx. I could never go back now, especially with my tim cameron tendencies, its just awesome!
  27. #107
    83
    Same way of feel. I turned down the punch 60% and adjust the drag brake as you did, I love it. I'm still messing with the power curves. At first I was bummed that the lvd in my EVX2 took a crap and my titan 775 burned up. Now I'm glad it happened cause I wouldn't have tried out my castle system in it. Awesome!
    NOTErized!
  28. #108
    1,539
    Fresh ideas?
  29. #109
    Germany
    72
    yes...
    Summit & E-Maxx
  30. #110
    Aug 2008
    St Amable , QC , Canada
    180
    Here my summit that i begin to build at the end of december 2012, a lot done , but got a lot of work to do on it !
    Some specs :
    Name : Ford Raptor Summit Scale ( need to find a real name)
    motor : Ballistic 5.5 550 sensored
    ESC : Mamba Max Pro
    Spur/pinion : 11/72
    Batts : 2s lipo 7600mah or 3s lipo 6000 mah
    speeds : not test yet
    Run time : 2hr estimated with most trail and crawl
    WHEELS/TIRES : Proline sc beadlock / 2.2 rock crusher tires mod to fit 2.2/3 wheel
    BODY : Jconcept fort svt raptor illuzion
    Suspension : Stock long travel
    Suspension arm : slayer
    Radio sys : Futaba 4pk
    I really love the way Noir522 did on his gecko with the 2 front end that i start mine the same way to achieve my four wheels steering truck !! My goal was to be close to a 1/10 scaler like the honcho and i reach it very close !
    other mod , i put proline bumper , hitec waterproof servos in the back for steering .
    wheelbase of 12.5 inch and a width of 11 inch !
    Not finish , still in project
  31. #111
    Richlandtown, PA
    44
    Castle Creations 1/8 MAMBA Monster 2 25V WP ESC, w/2200Kv motor
    Traxxas Aluminum GTR Shocks
    Hot Racing aluminum suspension arms
    Hot Racing Aluminum Knuckles-Axle Carriers
    Integy Aluminum Shock Mounts
    Golden Horizons Aluminum Rocker Arms
    Proline Trencher X 3.8" Mounted on Desperado Wheels
    T-Bone Racing Front Bumper/Skid Plate
  32. #112
    1,539
    any more creations out there?
  33. #113
    NNJ
    87
    2150kv
    120 amp wp esc
    Stiffer rear springs
    Trenchers
    Assorted bolt ons here and there
    (True track rear and rpm fronts ready for install)
    Finally found some axial narrow beadlocks. They're on the shelf waiting for some mudslingers.
    Also thinking of getting an under chassis guard. Anybody use those?
  34. #114
    1,539
    Still looking for more creativity, and DON'T spare the details.
