Page 4 of 4 FirstFirst ... 234
Results 121 to 134 of 134
  1. #121
    Sacramento, CA
    588
    motor : Titan 775
    ESC : EVX 2 with LVC
    Steering: complete aluminum set up with a Hitec 7950TG high torque servo (single servo setup)
    Body Armor: full T-Bone skid plate setup ( A-arms and body skids)
    Spur/pinion : 68/12
    Batts : (2) SPC 2s lipos in series(6500)
    speeds : 18 mph max
    Run time : 1 hr 15 mins crawling with little bashing
    WHEELS/TIRES : Pro-line F11 w Mudslingers
    BODY : Stock with Pro-line scale accessories and Pro-line 73' Ford Bronco
    Suspension : Stock long travel w/ 80wt oil
    Radio sys : Traxxas TQi 2.4 gHz
    # of lights : 18 total: 2 under carriage for night crawling.
    Sent from my iPhone using Tapatalk - now Free
  2. #122
    2,005
    name : Project 005mot : SumVee HDE
    motor : Tekin truggy motor 1700 kv
    ESC : Tekin RX8 encased in aluminum waterproof box
    Steering: custom 4WS system, powered by 611 oz torque Hitec 79800th in the front and a 611oz torque 7990th in the rear
    Body Armor: custome N-bone skid plate . Longer due to the longer chassis and shaped to protect the rear steering system
    Spur/pinion : 72/8
    Batts : (2) SPC 2s lipos in series(9000)
    speeds : 17 mph max in high gear , about 7 in low gear
    Run time : 1 hr +
    WHEELS/TIRES : MULTIPLE, all mounted on 23mm rims ( mudslingers, losi claws, trenchers, mashers, etc etc)
    BODY : proline hummer H2 SUT with custom rack
    Radio sys : Spektrum DX4S
    # of lights: stock plus 4 in light bar
    Bolt ons : Led light bar, 23mm hexes, aluminum servo guards, aluminum diffs and hardened steel gears, aluminum esc enclosure, Castle BEC to handle the servos,
    Custom : everything else. custom rook rack, added body fenders, custom rear steering system, Custom skid plate to protect the rear steering system, chassis cut to allow the 72t emaxx gear motor sacers to allow the 8t pinion gear,
    http://traxxas.com/forums/showthread...EERING-(-4WS-)
    MAN, Use Common Sense
    Funky Gecko, SumVee HDE
  3. #123
    Apr 2013
    Ontario, Canada
    778
    Codename: Zeus
    Just completed last month by putting in the new Tekin power system and New Savox Servo , Over $2000 invested in it. 100% Mechanical condition, only a few scratches on the bumpers/skids and body. This took almost a year to complete, The ENTIRE truck has been ripped 100% apart , cleaned, lubed and re-assembled. I have shimmed diff`s, very well. They were filled with 120k diff fluid and then the bulkheads were filled with the hot glue mod to re-enforce the bulkhead. Its HEAVILY Modded with most available upgrades plus some that are not even on the market yet like the LEM aluminum axles It has a Tekin RX8/T8i Gen2 1550kv power system(which has been waterproofed) with a Savox metal gear servo(which has been waterproofed) . The motor, ESC and servo have all been water-resistant tested, There is an adjustable LVA mounted on the chassis for added protection. The body is attached by a Velcro mod on the battery doors , much easier/better in my opinion. But the posts and twist-tops are still there and functional as well. Kind of a double secure system. The stock TQi 2.4GHz radio system (tx/rx) are also included. The body posts have been lowered. The battery vents have been modded to allow for the battery cables to be routed through them. The truck comes with Pro-line Trencher 40 Series tires on Tech 5 Wheels, They have been taped to reduce ballooning. They also have been balanced, this is visible by some small amounts of modeling clay inserted into the inner rim.
    10 months ago It started as a brand new Traxxas Summit.
    Then added the following:
    -Tekin RX8/T8i 1550kv Power System (waterproofed)
    -Savox 1230-SG Metal Gear Steering Servo (500oz@6v) (waterproofed)
    -Integy Aluminum Pillow Ball Caps
    -Traxxas Double Orange Springs All-round
    -Integy Aluminum Servo Horn
    -Integy Aluminum Servo Saver Set
    -Tbone Chassis Skid
    -Dusty Motors Shroud Cover
    -Roof light bar
    -Integy LVA
    -RPM Front and Rear Bumper Mounts
    -Ham Sandwich Mod
    -HD Slipper clutch
    -GH Aluminum Servo Guards
    -GH Aluminum Center Skid
    -Traxxas Servo Plate
    -Traxxas 65t spur gear
    -TQi 2.4GHZ TX/RX
    -RRP 11t Pinion
    -T Bone Racing A-Arm skids
    -Leading Edge Machining Aluminum Diff Cups
    -Traxxas Steel Center CVD`s
    -LEM Hardened Differential Spider Gears
    -Trenchers on Tech 5 Wheels (Taped)
    - Pro-line Body Secure-loc System
    CLICK HERE FOR THE SLIDE SHOW!!!!!!!!!!!
  4. #124
    Aug 2012
    windsor ontario
    43
    my summit : castle creations 2200kv system , geared 18/68 esc in custom aluminum oil filled box , junfac ressi shocks on rear , dyed chassis, chassis braces hardened rear/front diffs ,home ade aluminum skid plates ,slash 2wd front bumper , axial really narrow rims , 40 series rock crushers studded oh and two completely broken bulkheads thatt are barley holding together ,, srry for crappy pics lol
  5. #125
    2,005
    Do not wither with the passage of time. Allow eternity to regard your name forever. Cast your summit in the stone scribing of history.
    Post up ye fools
  6. #126
    Oct 2013
    Finksburg MD
    138
    Motor : Castle Creations 1717 1580kv
    ESC : Castle Creations Mamba Monster
    Spur/pinion : Robinson racing gen 3 65t spur -Robinson racing 13t pinion
    Batts :two 5500mah 3s=22.2v lipos
    Speeds : 30+or-
    Run time : Long enough
    WHEELS/TIRES : painted CEN GENESIS 7.7 wheels-tires
    BODY : Stock traxxas summit body
    Suspension : 120 long travel.4double orange springs-front and back
    Radio sys : Traxxas TQ 4 channel
    # of lights : 8 super bright 10mm leds moded with stand alone 6v bec and gws esc,controlled by 4th channel on radio.
    Upgrades Rpm arms,rpm knuckles with oversized bearings,mip drive shafts,hot racing Cnc motor mount,hot racing steering assembly,hot racing front and rear shock mounts,American CNC Machining 23mm wheel adapters,Dual Hitec servos,traxxas center driveshafts,blue printed locking diffs "shimmed tolerance to tenths" ,transmission converted to single speed.
  7. #127
    1,538
    Quote Originally Posted by Cky View Post
    Speeds : 30+or-
    Why did you remove the 2 speed transmission? Probably not necessary with the 1717 no?
    And how are the diffs holding up with such a powerful monster motor?
  8. #128
    Oct 2013
    Finksburg MD
    138
    The first gear for crawling could not withstand the power form the motor,by eliminating I am using just the main second gear gear thats a lot,a lot stronger.plus having a spare channel to control led lights is awesome.alazingly the diffs are very good i have been bashing with them for over a year and "knock on wood" they are still holding up.
  9. #129
    Jan 2007
    80
    Here is my Summit I have owned for 2+ yrs now. Love this beast!!!! A lot of nice trucks on here guys, nice to see Listed below are my specs and pics, enjoy
    Body: Stock, HPI 79 F250 (not even painted yet)
    Wheels/tires: Some seriously beat stock Canyons that have been repaired to many times, lol Got some Proline TrencherX on black desperatos 1/2" offset, Proline Rock Rage on F11's 1/2" offset (currently on backorder)
    Chassis: Stock but dyed all black with RIT
    Suspension: Integy adjustable from 90-120 travel, 25lb springs front and rear, stock links, 40w oil
    Steering: Stock for now
    Driveshafts: Traxxas steel center shafts, MIP front/rear (should be arriving anyday)
    Tranny: Stock
    Servos: Stock
    ESC/motor: Stock EVX2 w/lvd and 14.4v Dewalt (installed currently), Castle Sidewinder 8th waterproof esc/2200kv system (not installed yet), Novak Diablo sensored esc/550 2pole system (not installed yet)
    Radio: Stock 2.4ghz not the fancy newer one
    Batteries: Traxxas 5800mah 25c x4, GH 5000mah 30c x2
    Diffs: Stock for now, soon to be LEM or HR? 50,000 weight oil
    Gearing: 15/68 with Dewalt, haven't run the other systems yet to know yet
    Everything else stock... haha for now
  10. #130
    1,538
    Nice color dude
  11. #131
    Sep 2013
    Maysville,Ky. USA
    425
    Overkill
    Motor :Castle Creations 1/5 scale 780kv 2028 (about 3 pounds worth of motor)
    Esc : Castle Creations XL2 not waterproof yet
    Batteries : 8s (2-4s) in series 5000 mah 65/130c , 8 gauge wires with 8mm bullets
    Bec : Castle Creations Pro Bec - waterproofed
    Slipper clutch : Hot Racing HD slipper
    Steering : dual Savox Sg1230sg - waterproofed
    Receiver box : aka(the rats nest) bigger and some what waterproof
    Suspension : Kershaw Design A Arm Extension Kit
    Springs : Honda 70 atv outer valve springs in rear front springs revo extended springs with honda 70 inner valve springs
    Chassis : Kershaw Design aluminum chassis stretched 2 inches by me
    Drive shafts: plastic but extended, Waiting on LEM for aluminum ones
    Tires : RC4WD Super Swampers with smaller lugs removed , mounted on dual stock Summit rims
    Body : New Bright Fordf150 Raptor hard body with a few lights
    Gearing ; 18 tooth pinion 72 spur with added gear reduction (top speed in first gear 4.4 mph)(2 gear top speed 12.3 mph)
    Diffs: stock front - rear diff with heat treated spiders by me with JB weld epoxy. 2 LEM alum diff cups waiting on a full set of hardened gears.
    Tx : stock TQI 2.4
    Price tag : I won't even try but cheaper then i had planned.
    Homemade roof rack for holding spare batts, homemade rear hitch and a cool tool box
    Future plans : heavy duty winch and snow plow and a Tx to run the new stuff , LEM aluminum diff cases
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    1/10Overkill
    1/10Sum
    1/16Sum
    1/16Rally
    Rustler
  12. #132
    Jan 2007
    80
    Overkill... that truck is freakin nutz!!!! LOVE IT
  13. #133
    Sep 2013
    10
    [QUOTE=Sactown_Summit;5579803]motor : Titan 775
    Spur/pinion : 68/12
    speeds : 18 mph max
    Do thoose wheels fit perfectly in the Summit? Donīt they rub?
  14. #134
    Newcastle, Australia
    949
    Name: The Big Hoss
    Motor: CC1515 2200kv (trial run) or DeWalt 14.4v
    ESC: Mamba Monster 2
    Spur/pinion: 18/68
    Batteries: 2x 2S 7600 or 6000mah 40C in series- 4S
    Speeds: Speed Calculator says 40mph- Don't know for sure
    Run time: Guessing 30-40 minutes
    Wheels/Tyres: RC4WD Mudslingers on Traxxas Geode 3.8 rims
    Body: Green Stock Summit with latest graphics, lowered
    Suspension: Stock long travel with 60wt fluid, just under 6" of ground clearance
    Steering: Single Servo Setup- MG959 30kg Servo, Aluminium horn, Hot Racing servo saver
    Radio sys: TQi 2.4ghz 5 channel
    # of lights: Stock- 10
    All Modifications: ESC, Motor, Tyres, Servo, Servo Saver, Paint here and there, Dechromed Rims, Aluminium cover plate for spare servo hole, body lowered
    Pictures:
