+ Reply to Thread
Results 1 to 11 of 11
    Jan 2007
    regina sask, canada
    2,344
    My new to me Slash
    well it was in a little rough condion but im going to fix it up
    it was realy dirty but you cant realy tell by the pics
    before
    <a href="http://s168.photobucket.com/albums/u193/scotthw/Slash/?action=view&current=Slash.jpg" target="_blank"><img src="http://i168.photobucket.com/albums/u193/scotthw/Slash/Slash.jpg" border="0" alt="Photobucket"></a>
    After
    i made a ESC plate of stainless steal so i could remove the esc with out having to pull off the servo tape
    and i put in a new power sytem and my DX2.0 radio sytem
    i also pulled it all apart and gave it a good cleaning
    i am going to get a new body for it since the stock one is in bad shape
    what you guys think
    if your not breaking anything get more air
    Feb 2008
    sterling hts MICHIGAN!
    2,037
    that body is not in bad shape o:
    if you want me to i can break your truck for free!
    Jun 2008
    Abbotsford BC, CANADA
    2,228
    it was never dirty atall! my slash has been a mud ball, literally either way, nice slash!
    Lead, follow, or get out of my way!
    Jan 2007
    regina sask, canada
    2,344
    not sure why it posted the same pic three times it was working when i posted it
    but here are the other befor pic
    thecoolman101 well you cant tell by the out side but on the inside its cracked in the roof in two spots and its crack in the back at two spots and some of the paint is starting to were off were the tires rub and in a few other spots so i put ducted tape were the tires were rubing
    and i really want a new body any way
    SLASHPEDE i know it could have been alot worse
    i just wish i new what was wrong with the esc so i wouldnt have to run that other battery its like the esc isnt sending enough power to the RX when i give it full throttle and it loses signal
    you guys got any ideas how to fix this
    May 2009
    World's Largest Archipelago
    1,173
    LOL the before pic looks pretty clean already to me...
    Now this IS dirty.. took me a whole day to wash it.
    That esc mounting plate would be better off made from non-conductive material such plastic or at least cover it with some duct tape. Just in case a wire(s) is loose, the + and - ends make contact via the mounting plate. Yikes!
    Myth busted: Blitz is not faster on the track.
    Jun 2007
    NOT HERE ANY LONGER
    1,852
    Looks like you got a pretty nice truck there. I've bought and sold a ton of slash's and I think you got a deal.
    I bought a truck from a guy and when it arrived it was covered in mud and looked just like Outofsights pic. I just removed the ESC and sprayed the whole thing down with a hose. Just make sure you go back and lube all the metal parts and bearing with a drop of bearing oil to prevent rusting.
    My mother
    Reba Collins 6/30/52 - 3/1/10 1:13pm
    May 2009
    1,173
    ^what he said^.. wet mud corrodes metal parts pretty quickly, especially when running on 1/8 nitro buggy tracks, because fuel residue left on the track will worsen corrotion. WD-40 works best prior to doing wet runs.
    Jan 2007
    regina sask, canada
    2,344
    ya i think i got a good deal i trade my stock proboat fomula fasteck boat for it
    Loveland, Ohio
    733
    Quote Originally Posted by Out of Sight
    the caster oil will help prevent corrosion
    get on the castle link and check if the bec voltage is the correct voltage, you should set it at 6v
    Orange Powered
    Novak BL
    Aug 2010
    Beaumont, tx
    151
    Quote Originally Posted by scotthw
    I would ditch the battery on the side and get a CC 10amp BEC. That would cut out the bec in the ESC and take the load off of it.
    May 2010
    St. Louis MO
    277
    +1 what lazyboy42 suggested. Link your esc to your PC and see how it's programmed. The previous owner may have changed the settings. Start by changing it back to the default settings and go from there.
    If that doesn't work, check for a broken receiver wire. Does your slash have the same problem 6 feet away as it does 100 feet away? If not it may be a broken wire.
    VXL Slash, Castle Slash, XL-5 Rusty, 2002 Pede
