i,m having trouble reversing the servo on my remote for my mamba motor . thats even when using te very confusing manual. can somebody explain it to me in laymans terms?
If you are trying to reverse the servo because the motor is running backwards, don't. You only need to switch any two wires from the motor to the ESC around. That will make the motor run forward with forward throttle. If this is not your problem, sorry I can't help.Originally Posted by yotaman1991
that might be the issue but castle is sending out a new motor to me due to a bad motor . ill try when it comes. should have thought that myself.![]()
threw the stock bl back on and you were right, thanks.
