+ Reply to Thread
    Apr 2009
    San Diego, CA
    171
    Cleaning with a MMM 2650 combo
    For those of you who clean your trucks, how are you doing it with the MMM 2650 combo not being waterproof? I have used baby wipes in the past but wanted to know what has worked for you.
    Thanks!
    4x4 Slash PE
    Feb 2004
    California
    589
    I used canned air, costco carries canned air at 6 cans for $17.99 and the pressure is very strong. I also use a tooth brush, small paint brush and stiff brush to get all the dirt that dries on the R/C. I also use WD40 to clean everything down good and it also assist with repelling dirt/dust later on.
    The other way you can clean it off if you want to use water on the 4X4 just tilt it so the front wheels are up in the air and rinse of the rear wheels and area once all the water drains off, do the same for the opposite. Then take canned air or pressured air and blow off the water. Just keep in mind that eventually you'll need to clean your bearings because they will rust eventually. That's my .02 cents. Good Luck!!
    FangsCPO
    "How fast was I going Officer?" Wow?
    Jul 2005
    NB, Canada
    293
    I use a hose on low pressure and hold the truck at angles the water wont hit the esc or motor, then wipe it down with a rag. The good news is I never have to clean it much cause its always broke or waiting on parts.
    Germany
    1,552
    You could coat the ESC in Plasti-Dip to protect it from water.
    Jul 2010
    Central NJ
    18
    Quote Originally Posted by FangsCPO
    I like using my compressor in the garage. If you don't have a full sized compressor this would do well:
    http://www.harborfreight.com/1-4-qua...sor-90168.html
    They sell kits with the air gun attachment.
    If you are getting your air by the bottle this would pay itself of quickly.
    ***Edit***
    The only drawback to using compressed air is if anything paper is wet it will blow right off the item.
    Jan 2010
    Tyrone, Central PA
    512
    HK Brushless Summit!!!
    Apr 2009
    San Diego, CA
    171
    You guys rock, thanks!
    4x4 Slash PE
