    Apr 2010
    Abbotsford BC
    476
    steering servo twitching, won't center
    finished my rebuild and ran the truck for a couple of minutes, then the steering suddenly turned left and didn't want to self-center. Check linkages and it's all fine, spray some lube on everything and turn it back on. Servo is twitching like crazy and randomly goes to 2/3 left.
    Any thoughts?
    May 2010
    161
    water damage maybe. could be receiver, could be transmitter. will it do it with the radio off?
    S4x4 MMM,1512CC,RPM,MIP
    Revo MMM,1520CC,RPM,MIP
    Apr 2010
    Abbotsford BC
    476
    with the radio off the whole truck does the jitterbug and often runs away, so I never tried.
    Checked the Rx and it is clean and dry.
    El Sobrante, Ca
    7,369
    You might want to call Traxxas. They can help you diagnose your problem.
    May 2010
    21
    sounds like the servo pot is damaged.
    Apr 2010
    Abbotsford BC
    476
    Quote Originally Posted by Remy5405
    It was the transmitter after all.
    First I plugged in a spare servo from my 18T and it did the jitterbug as well, so I swapped radios and had no more problems.
    Disasembled and cleaned the pot for the steering today, but haven't got it back together yet to see if it works now. Hoping I just got a bit of dirt in the wrong place or something.
    Feb 2004
    California
    589
    I say bad servo. Easy to replace and if its still under warranty call traxxas. They'll take care of you, if not, it's not too expensive to replace.
    FangsCPO
    "How fast was I going Officer?" Wow?
    Apr 2010
    Abbotsford BC
    476
    cleaned the steering "pot" on the transmitter and it's all good. Some metal dust must have gotten into it when I was grinding down my nut driver to fit into the Pro-line 17mm hex adapters.
