Results 1 to 12 of 12
    Feb 2009
    Smyrna TN
    321
    Gearing recomendations for MMM 2650 on the 4x4.
    I see the package comes with an 18T pinion but what is everyone running gearing wise on the 4x4, those that have the MMM with the 2650 anyway. Thanks!
    Jun 2009
    Kylertown,pa
    127
    I run both 18/54 and 20/50 both are fast as heck.No heat issues but lots of traction issues.
    Slash 4x4 with MMM/2650kv
    Feb 2009
    Smyrna TN
    321
    Quote Originally Posted by fullmonte77
    Heheh, ok. Well the pinion that comes with it, is that the same pitch as the stock spur on the 4x4? Just trying to get everything together before it gets here. Thanks in advance.
    Apr 2010
    Sacramento, CA
    95
    I run a 24t/50T with no heat problems but like the fullmonte said, you can get some serious traction issues. Gotta boost up the punch control.
    WA - PNW - USA
    621
    how is speed with this gearing when running 2s batts?
    slash 4x4
    Apr 2010
    78
    WA - PNW - USA
    621
    Quote Originally Posted by DoogieLee
    shucks, it's missing the castle 2650 from the dropdown list - only see CM's represented. Also don't see the Novak 4.5 listed.
    is this your site?
    slash 4x4
    Jun 2009
    Kylertown,pa
    127
    Quote Originally Posted by Fanatic1074
    Yes its the same pitch.
    Jul 2008
    Chino, CA
    378
    The Castle 2650 must be under rated as far as KV goes because I bought an LRP Vector8 2800KV motor and it was slow as molasses geared 18/54, on 2S. I would probably need a 24 or 26T pinion to wake it up.
    Feb 2009
    Smyrna TN
    321
    Ok one last question about this....
    I dont see any markings on the ESC to identify what color wire goes into what slot. can someone tell me the color combo or does it not matter?
    Jun 2009
    Kylertown,pa
    127
    It does not matter.If the motor goes in reverse when it should go forward just switch any 2 wires.
    Ontario, Canada
    1,249
    18/54 or 19/54 puts you very close to speed of stk system 13/54,, I've found the 50 spur is the key to gearing it. It allows for adequite clearance with larger than 22 pinion, also allows for slight more clearance between spur and chassis.
    20/50 and 22/50 is very nice on 2s
    Al
    MMM/2650, E-maxx Body=FUN !
    3 Slash 4x4
    Pede 4x4
